Newer Bellhousing...will it bolt up?
I have an SM-465 bellhousing that's for a hydraulic clutch, will that bolt up to the stock crossmember on my 63? The truck has an SM-420 in it now, and I was wondering if it would be worth it to dig out the newer bellhousing. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
60-66 Nut
Re: Newer Bellhousing...will it bolt up?
That bellhousing can work, but you will have to remove the bellhousing crossmember, and add a rear trans mount. Which a SM420 does not have provisions for. You would also need an adapter ring for the front bearing retainer, as the '68 and newer bellhousings have a larger hole for the larger bearing retainer. If you need the hydraulic bellhousing, it would be easier to switch to the SM465.
Sorry, I should have included more details. I plan on using an SM-465/NP-203 combo as part of the project. I have a hydraulic clutch bellhousing for the SM-465. I was hoping to use the stock 63 crossmember, but it sounds like it won't. Is there a way to make it work? I was hoping to avoid drilling out frame rivets. Thanks!!!
IT looks like I'm going to have to remove the stock crossmember anyways. I did some more looking at the truck and noticed part of it was cut to clear the rear shackles for the leaf springs.
60-66 Nut
The original bellhousing crossmember will likely hit the bottom of that bellhousing. Besides you really don't need it in there since you will have a crossmember under the transfer case adapter anyway. If you don't want to deal with the rivets, just cut it off flush with the frame flanges.
