03-15-2012, 09:58 AM | #1 |
Quartz Clock for your dash
I have these clocks posted on the 73-87 classified but thought I would list them on here as well. I have picked up several more and they look as nice as these in the pic. This could be used to fill that vacant hole in your dash.
Each one was bench tested for several hours and worked great. Each one has had the face removed and then polished. The adjustment stem sanded and painted black and the hands painted as close to the original color as I could get. Some of them do have different second hands. Let me know if you have a preference. These are extremely sharp and will look great in your dash. Each one comes with a plug plenty of wire to attach to. These are easy to hook up. The black wire is the ground and the orange wire goes to the fuse box. $45.00 shipped to you. Money order or paypal. I Know I have a couple rubber grommets and I will include one with your clock until I am out. These really are sharp looking. Thanks I have five left as of now. |
03-15-2012, 12:12 PM | #2 |
Re: Quartz Clock for your dash
what year are these from?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-15-2012, 01:10 PM | #3 |
I think in 81 is the year GM switched over to the quartz movement. So I would say 81-87. Thanks
03-15-2012, 02:09 PM | #4 |
67cheby
here is a pic of mine installed, i think it is a nice touch
03-15-2012, 03:33 PM | #5 |
Dude..... that is SaWEET!!!!!
03-15-2012, 11:29 PM | #6 |
Can you show a pic of the backside as to see how it mounts ?
03-16-2012, 07:38 AM | #7 |
Here is a closeup of one finished and the back side.
03-18-2012, 03:04 PM | #8 |
ttt
03-23-2012, 10:45 PM | #9 |
bump
04-01-2012, 04:17 PM | #10 |
ttt
04-01-2012, 04:49 PM | #11 |
"GO DAWGS"
If I am not wrong the quartz are from 78 or 79 - 87 truck. These were also in Suburbans but the dial stem was @ 6 oclock on the Burbs.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
04-01-2012, 05:03 PM | #12 |
You might be right, but I thought they started the quartz in 1980. They are a direct fit for the trucks starting in 1973 until the quartz was introduced.
04-17-2012, 07:45 AM | #13 |
morning bump
04-17-2012, 02:01 PM | #14 |
All the quartz clocks had the adjustment hand at the 8 o clock position, truck, blazer or suburban it doesn't matter. The older non quartz clocks had the adjustment knob at 12.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-17-2012, 02:58 PM | #15 |
"GO DAWGS"
I knew that I have seen some clocks at either 6 or 12 o'clock I could not remember which one it was but they were listed as coming out of a Suburban. I will try and find a pic of one. Here are a couple of pics 3 o-clock is a van and the 12 o-clock says suburban, blazer and truck.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops Last edited by PT'S 70 CST; 04-17-2012 at 03:24 PM. |
04-17-2012, 03:18 PM | #16 |
If you could find a pic that would be great. I have never seen one at 6 o'clock. I am always wanting to learn something new. Never have to much information.
04-17-2012, 03:21 PM | #17 |
Anything in first gen. camaro?
04-17-2012, 03:30 PM | #18 |
There used to be a company called Clockworks that did quartz conversions but I don't know if they are still around. Back in about '93 pr so I sent my factory 71 Nova clock to them and had it done. It still keeps perfect time to this day!
04-17-2012, 03:35 PM | #19 |
C/10 junkie
Only thing I have is an original 7 blade radiator fan but I am wanting to use it for my build.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
04-17-2012, 08:03 PM | #20 |
I am not sure if that company is still in business or not. I bought a quartz movement for my 69 camaro off ebay and installed it myself. Very easy to do. The only difference is the quartz has a sweeping second hand where the non quartz second hand would click for every second.
04-17-2012, 03:26 PM | #21 |
If the knob comes out at 12, it will have the older style numbers and wont say quarts on it like 67cheby's pic in post 4. IMO the older style matches the 67-72 dash better. I always swap the faces, since how you mount the clock doesn't matter. But they are not a direct fit, you have to epoxy them on, but then you can have an older looking click that actually works.
04-17-2012, 03:33 PM | #22 | |
04-17-2012, 03:18 PM | #23 |
C/10 junkie
Anything you would be willing to trade for one?
04-17-2012, 10:33 PM | #24 |
C/10 junkie
Thanks Carl. I picked it up cheap so I was gonna use it on my 327 build. Thanks for the info. Anything else you may want to trade for? Let me know.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" Last edited by shawno72; 04-18-2012 at 12:05 AM. |
08-21-2012, 02:01 PM | #25 |
Just picked three more. All have been tested for 24 hours and kept time. The face was polished, the hands painted and the stem painted black. These do have the chrome knob and small set screw. These also have the rubber grommet that goes in the plastic lens in the dash. These are easy to add to your dash. The wires were cut but have plenty of wire to attatch to. The orange wire goes to the fuse panel and the black goes to a ground. $45.00 shipped to your door.
