![]() Join Date: Feb 2004
1970 Burb , plywood floor in the back?
Mine looks factory, we're they all wood or were some steel?
Posted via Mobile Device |
Re: 1970 Burb , plywood floor in the back?
My 67 has plywood too. I think they all were that way.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
BlahBlahBlah
All wood
So do y'all keep it plywood or swap it out for metal? Or wood slats like the wood truck beds? I think a nice steel or aluminum diamond plate would look sick
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
![]() Join Date: Jul 2011
When I got my burb the plywood deck needed replacing. So I replaced mine with marine grade plywood.And it was quite the project. So I would imagine that most people leave it alone. Unless it needs replacing.
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 ![]() Shawn |
BlahBlahBlah
Ive never taken the wood out of a burb, I heard it was a very labor intensive job.
i am planning to put wood bed slats in mine
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
low n' slo
![]() Join Date: Mar 2009
It is...and it sucks. Had to pull it for the notch. I plan on wood slates when i get back to the interior...
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
