Old 03-17-2012, 06:18 PM   #1
ffk
ffk's Avatar
pinion nut
hey im looking for the tourqe spec. on the pinion nut on the rear end..i cant remember yes im getting old.
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 03-17-2012, 08:40 PM   #2
oldspowered67C10
Re: pinion nut
What kind of rear end? If its a 12 bolt there really is no spec, just tight enough to preload the pinion bearings correctly.
oldspowered67C10 is offline   Reply With Quote
Old 03-18-2012, 12:24 AM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: pinion nut
You need a rotating torque spec.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-18-2012, 02:48 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Re: pinion nut
^ x2
The in-lbs of rotational effort required is different for new bearings and used bearings too.
You really need a dial indicator type inch-pound torque wrench to do it properly.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-18-2012, 02:53 PM   #5
ffk
ffk's Avatar
Re: pinion nut
12 bolt 1/2 ton posi..new bearings..i know the crush sleeve has to crush but..i dont want to over tighten...
Old 03-18-2012, 03:41 PM   #6
425HP409
425hp409
425HP409's Avatar
Re: pinion nut
The proper way to do it is to have a beam type torque wrench that goes in small increments, 1/4 or 3/8" drive, so that you can read 5 inch pounds of rotating torque. To get an accurate reading make sure that the pinion races are seated ALL the way and the bearings are lubes with oil.
First you tighten the pinion nut so that the slack in the pinion is just taken up. Then tighten the nut a little at a time, measuring the rotating torque after each tightening, until you get the 5 inch pounds of rotating torque. You are then done. The crush sleeve is now "crushed" and has the proper load on the pinion bearings.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 03-18-2012, 06:12 PM   #7
hayhauler71
hayhauler71's Avatar
Re: pinion nut
15 in lb used bearings 25 in lb new bearings that is rotational force
Fuzzy
hayhauler71 is offline   Reply With Quote
