03-18-2012, 12:52 AM | #1 |
61-62 283 with 2spd glide
I have a complete 283 with powerglide for a 61 or 62 pick up. I am going to use a 327 for my build so don't need this.400 OBO
03-18-2012, 10:48 AM | #2 | |
Re: 61-62 283 with 2spd glide
By real deal, I mean that it has the MA suffix code on the pad in front of the right head and curious to know if it has a 60 or 61 date code on the intake behind the carb. Also need to know when it last ran, how bad it smokes, knocks etc if known. Not sure I can afford to ship it even if you were able to palletize or whatever so all this might be a mute point, but let me know your zip code so I can check around and see what kind of rates are out there. Curious to know what 60-61 specific parts and options you have you are not using too? |
03-18-2012, 12:11 PM | #3 |
The number on the block is F06IIMA and the intake is a 3746826 with a gm 19 casting. The powerglide has a G789935 cast on it. I bought this out of a truck and I didn't start it but I did crank it over. I just figure if I don't have the numbers matching motor for my truck then I may as well use the 327 I have. This does have a block crankcase breather on the back so it is pre 64. My zip is 97495 and I could pallet it for you.I don't have any 60-63 parts now but I am always looking and know where a few are. Let me know if you are interested and if you aren't I will ebay it. I guess this would be a rare beast as it is a powerglide casting number and 90% of the trucks had a manual trans or a 6 cylinder.
03-18-2012, 11:32 PM | #4 | |
03-19-2012, 08:30 AM | #5 |
There is an antique tractor board I have used with guys that cross the US picking stuff up. I don't have it saved anymore but do a search, it was really cheap as they are travelling empty sometimes anyways.
