Old 03-18-2012, 04:02 PM   #1
robert_63
robert_63's Avatar
fuel guage insanity
just a quick question guys, i replaced fuel sending unit and been checkin wires, when i disconnect the wire guage reads full, and when i ground the wire(from the guage) to the frame it goes to empty, is this the correct reading? or should it read empty when unplugged and full when grounded? ive searched the fuel guage threads and just cant seem to figure it out. any help would be greatly appreciated.
robert_63 is offline   Reply With Quote
Old 03-18-2012, 05:00 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: fuel guage insanity
when my ground was not making contact properly the tank would read way past full once the ground was tight it would read whatever the level of the tank was
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-18-2012, 05:17 PM   #3
robert_63
robert_63's Avatar
It stays around a 1/4 or little more its new sendin unit and have the ground from the top of unit attached to the frame
Old 03-18-2012, 07:01 PM   #4
joe231
joe231's Avatar
Grounded it should read empty
Open it should read past full
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-18-2012, 07:52 PM   #5
hatzie
Moderator
hatzie's Avatar
The gauge has a calibration resistor on studs at the back of the small can housing the movement coils. Sounds like you have a problem with yours.
More here...
http://67-72chevytrucks.com/vboard/s...02#post5241602
Old 03-18-2012, 08:07 PM   #6
joe231
joe231's Avatar
More here...
How did you arrive at that conclusion?
CHEVY ONLY
Old 03-20-2012, 03:13 PM   #7
hatzie
Moderator
hatzie's Avatar
The gauge reads lower than it should at full sweep.
Roberts' gauge reads F when the sender is unplugged. That's NOT OK. The needle should sit way past full (roughly 3:00) with the key on and the sender unplugged.
The 73-91 sender is a wire wound 0-90 ohm potentiometer with some mild swing damping. It can be tested with a multimeter set to the 100ohm scale. Attach one lead to the sender pin and the other to the round sender top.
The meter should read near 0 ohms with the float hanging.
The meter should read close to 90 ohms when the float set for a full tank.
I'd test the original GM sender if it's not pitched out yet.
Attaching a 90-100ohm resistor between the frame and sender wire should put the fuel gauge pointer near the F. The OP already proved that grounding the sender wire moves the gauge to E.
Old 03-20-2012, 11:26 PM   #8
joe231
joe231's Avatar
Oh
Gotcha
I missed that the first time.
CHEVY ONLY
Old 03-18-2012, 08:35 PM   #9
robert_63
robert_63's Avatar
One thing i have found on here is guys posts sayin when the wire is off or "open" the guage goes past full some sayin it goes to like the 3 0'clock position mine just goes to maybe a hair past the full mark. i have checkd the wire all way down the frame and to the crossover solenoid and when unplugging it the gauge does the same to just a hair past ful or e when grounded out. beginning to wonder about the oreilly's sendin unit.
Old 03-18-2012, 09:04 PM   #10
tucsonjwt
Are you saying that your fuel gauge does not read correctly after replacing the sending unit?
tucsonjwt is offline   Reply With Quote
Old 03-18-2012, 09:21 PM   #11
My gauge was doing the same thing yours is. I replaced the gauge and everything is good now.
Old 03-18-2012, 09:24 PM   #12
robert_63
robert_63's Avatar
yeah when hooked up it goes to 1/4 thanks 70step i will try get me a guage and see
Old 03-18-2012, 09:30 PM   #13
I got lucky and found a decent cluster in a pick and pull. Several of my gauges got replaced with the ones from that cluster.
Old 03-18-2012, 09:44 PM   #14
1425956
1425956's Avatar
Mine jumped around a lot too so I replaced the sending unit. It doesn't drop around much now but it still reads way past full and stays there for about 100 miles; then, once it starts to move, it drops fairly quickly.
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 03-18-2012, 09:53 PM   #15
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: fuel guage insanity
Good Post.
I have had trouble with my 73 C/20 ever since Ive owned it.
It has never read correctly the amount of gas in the passenger's side GM tank.
Would you guys suggest starting there and working forward, or at the Gas Gauge in the dash back?
Can a bad printed circuit also cause a bad reading as well ???
How would the stock gas gauge read dual tanks; being a 73 and not a factory dual tank option...but an added driver's side GM tank?
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 03-20-2012, 09:11 AM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
my 78 gauge jumped till i swapped over to tach cluster
I added grounds behind the cluster where they all go down to one
now no probs
bout a foot from the cluster plug
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-27-2015, 08:41 AM   #17
E.TexasTwister
I just got this truck Sunday. (72 c10) I drove it about 400 miles and every time I stop for gas it would show way past full. Like some said above around the three o'clock area.
It would run about a 100 miles then drop pretty rapidly.
What fix did anyone find out on this?
E.TexasTwister is offline   Reply With Quote
Old 01-27-2015, 10:20 AM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
I'd check tank ground,sender wires to start....
if the sender wire is cut it's usually over full @ 3,
shorted out would be stuck E.
John
Old 01-27-2015, 11:04 AM   #19
hatzie
Moderator
hatzie's Avatar
Since it moves with the fuel level... That sounds like a gauge range problem not an open sender wire.
More resistance than there should be in the sender wire would cause this. A bad gauge or bias resistor could do it as well...
When she gets to empty does the gauge read E or is it reading 1/4 or more?
With the tank filled what is the resistance measured from the TAN sender wire on the cluster plug to a good ground?
This might be better answered on the 67-72 section of the boards.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
