Hey guys,
One of my friends has a 79 step side and it has a 6 inch suspension lift in it. I was wondering if anyone here would kno what the biggest tire he could put on without rubbing. I kno you guys are great with these type of things and i greatly appreciate any info you could provide. thanks. Dan ------------------ 1981 Chevy Silverado 468 cid big block Edelbrock Tunnel Ram Dual Quad Intake (2 600cfm edelbrock) 11.5:1 compression Comp roller cam and lifters Comp cams roller rockers Steel Manley connecting rods MSD-10 ignition with Pro Billet distributor Pete Jackson gear drive timing gears Saveing for a set of Alluminum heads and an 8-71 Blower
1981 Chevy Silverado 468 cid big block Edelbrock Tunnel Ram Dual Quad Intake (2 600cfm edelbrock) 11.5:1 compression Comp roller cam and lifters Comp cams roller rockers Steel Manley connecting rods MSD-10 ignition with Pro Billet distributor Pete Jackson gear drive timing gears Saveing for a set of Alluminum heads and an 8-71 Blower |
I have on 35's with a 6" lift
could run 36's up to 38's depending on if you go offroad or not.
http://community.webshots.com/user/gtkustoms |
