03-22-2012, 09:34 PM | #1 |
is my truck a 3/4 ton or a 1 ton?
when i bought my truck the guy said it was a 1 ton. according to the vin, it says its a 3/4 ton, but i dont know. i have a 14 bolt eaton posi with 4:11 gears. i have huge leaf packs with overloads. the emblem says sierra classic 25. So is it a 1ton or a 3/4 ton?
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
03-22-2012, 09:53 PM | #2 |
Re: is my truck a 3/4 ton or a 1 ton?
That is a 3/4 ton. If you look at your last pic, the shock is bolted to the outside of the frame. On a 1 ton they are inside of the frame rails.
1949 Five Window, 1973 Step Side, 2000 Z71 |
03-22-2012, 09:55 PM | #3 |
If the vin says 3/4 i'd say 3/4. full floaters could be ordered with both i believe.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
03-22-2012, 10:01 PM | #4 |
ok thanks guys!
