![]() Join Date: Mar 2008
'86 K35 parting out
'86 K35 for parts. Ex-Ontario Hydro truck. "Should" be 4.56 front and rear, according to paperwork that came with the truck. Transfercase/adapter NOT for sale. Should be cab and chassis frame/rear diff.
Snowplow, Northman 8 foot blade, working when pulled, $300 for everything you pull, $500 I pull Running Targetmaster 350, $200 you pull, $400 I pull Working TH400 tranny, $200 Driveshafts $75 each if good Front Dana 60 $1000 (not inspected yet) Rear 14 bolt, $500 (not inspected yet) 5 cab roof lights, $50 Grill and trim and bezels, $75 Column, non tilt, with key, $65 Doors, good bottom seam from a quick look, $100/pair Mirrors and mirror arms, $50 Front bumper, $65 6 rims, $120 Tires, all 6 for $180, front two are like new, back 4 are in good shape Anything else please ask Motor can be heard running, truck is still driveable tonight (no brakes, use e-brake pedal ![]() |
Re: '86 K35 parting out
Look over the doors a little better and let me no how good they are if you wouldn't mind. If they are real good I will take them.
![]() Join Date: Sep 2010
why you gotta be so far away ?
I think I will be going for a drive up there in 2 weeks april 7th or 8th which is a Saturday or a Sunday. I will take the wheels then if thats okay with you. I will pass on the doors thou since they are not OEM doors. Are you going to be cutting that cab up, is it scrap. If so I am still looking for a patch panel cutout around the rear of the cab by the rear window. Basically where the rear cab trim would go.
Top- Let the raping begin!!!
Cab lights, rubbers, screws and harness $50 (harness has been cut where it goes into the dash) |
Bump for axles. Both diffs are 4.56 open carrier. Gears appear to be in great shape, no rust, low mileage, oil is nice and clean.
Do you have GMC Cab corners on this truck?
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
I don't know, but both are rotten. Sorry.
Pics of RH rims for madcow75:
RH door pics for madcow75:
LH rims:
