Old 03-23-2012, 02:31 PM   #1
1stchevy
1stchevy's Avatar
Front suspension binding
I purchased a 4/6 drop from ECE, installed the spindles, springs, disc brakes, ball joints and tie rod ends. After I set the truck down on the ground it will not drop down like the suspension is binding but I can't figure out where. Any suggestions of what to look for or where to look at?
1stchevy is offline   Reply With Quote
Old 03-23-2012, 02:42 PM   #2
GEARBOXGARAGE
Re: Front suspension binding
Did you also use a front sway bar? If you did, make sure you have the weight of the truck on the suspension before tightening the bolts to this. I also used there spindles, springs (3.5" drop in front) and front sway bar and had this same problem. I called them with this exact same question and they said the same as above. But I still feel the front may be to high.... Maybe it will settle after driving?? Don't know.
GEARBOXGARAGE is offline   Reply With Quote
Old 03-23-2012, 02:43 PM   #3
big_al_71
big_al_71's Avatar
I would look at all the moving parts of the suspension,
springs, control arms I would also look at the INNER AND OUTER TIE RODS TO MAKE SURE THERE IS NOT ONE BENT.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-23-2012, 03:07 PM   #4
1stchevy
1stchevy's Avatar
No sway bar but I did notice I mounted the upper ball joint to the bottom of the control arm instead of the top. All the tie rod ends look good.
Old 03-23-2012, 03:15 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Pics of the inner tie rods?
It's very common to assemble the centerlink backwards.
Keith
Convert to disc brakes.
Old 03-23-2012, 04:49 PM   #6
1stchevy
1stchevy's Avatar
I don't have any pics but I will take some later.
Old 03-23-2012, 08:44 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Have you driven it yet? The suspension could be preloaded from being put together in the air. Sometimes it takes a drive around the block to unload.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-23-2012, 09:08 PM   #8
1stchevy
1stchevy's Avatar
N2trux I have not driven it yet since I've lowered it I'm still working on the brakes. What's strange is I can take the spring out completely and sit the truck down and it will hold itself up instead of dropping down but I can push down on the truck and it will drop or I can put a jack under the lower arm and it will raise completely up.
Old 03-25-2012, 12:10 PM   #9
1stchevy
1stchevy's Avatar
I did see that the upper bump stop was resting on the front cross member so I pulled those out but still nothing. I'm stumped here guys!
Old 03-25-2012, 01:45 PM   #10
SCOTI
SCOTI's Avatar
Those upper bumpstops should only make contact when the suspension is @ full extension. They keep things from over extending & do not effect how much drop can be achieved.
Did you service the control arm bushings? Based on the gap I can see in the pics between the lower a-arm bumpstop & the bottom of the x-member, I'd say you don't have drop springs in there or the suspension is not under compression. With 2" drop springs, there would prob be about 2-3" of clearance between the bumpstop & x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-25-2012, 01:57 PM   #11
1stchevy
1stchevy's Avatar
No I didn't service the control arm bushings. I'm thinking now that I should have but they moved fairly free. I have been on the phone multiple times with Mark at ECE and the springs measure right but I can't figure out where it's binding. Everything is new except the control a shafts and bushings.
Old 03-25-2012, 03:15 PM   #12
SCOTI
SCOTI's Avatar
Is the suspension under compression (full vehicle weight) up front in the pics?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-25-2012, 04:48 PM   #13
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Have you actually rolled the truck forward and back? If you just drop it down, the tires move outward as the suspension compresses and if you don't roll the truck, the tires are too sticky to allow the everything to move outward.
Something to check.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-25-2012, 05:06 PM   #14
1stchevy
1stchevy's Avatar
I got it! The front springs were not seating, rookie mistake. My brother came over and we checked over everything then greased the front end. Truck sits down now. Thanks for all the help!
