Old 03-28-2012, 10:08 AM   #1
limeimac97776
Just Rebuilt my engine. What do you think of it?
Its a 1973 Chevy 350 2 bolt block originally out of a caprice. Its now bored .040 over, flat top pistons, original crankshaft, double roller timing chain, comp cams cam and lifter kit (cam has gross valve lift of .454), heads are 305 swirl heads off of a camaro with casting number 14102187, intake manifold is an edelbrock performer manifold with a holley street avenger 670cfm carb. Engine is painted chevy orange. And valve covers are factory gm covers off of a 1992 chevy truck I found in the junkyard lol. Cleaned all the oil of of them and repainted them black.
limeimac97776 is offline   Reply With Quote
Old 03-28-2012, 10:15 AM   #2
big10ratrod77
big10ratrod77's Avatar
Re: Just Rebuilt my engine. What do you think of it?
sounds like a good start man should have plenty of streetable hp and still look fairly stock
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 03-28-2012, 12:36 PM   #3
Dieselholic92
Dieselholic92's Avatar
Sounds like a good motor to start out with. I would definitely think about some different heads down the road. They are going to be holding power back
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 03-28-2012, 01:01 PM   #4
ChevyMutt
ChevyMutt's Avatar
I've always been told that 305 heads on a 350 will significantly increase compression. I ran a set on a 76 Monte Carlo I had back in the day and they dropped my 1/4 mile time by .5sec & made that old boat launch off the line...
79-87 3/4T Plow Truck. Running Gear all 79, body is 84-87.
Originally built by my Dad & Brother in late 90's early 00's. I bought the truck in summer of 11; dad & brother put new box sides on, and surprised me with a new paint job. Jan of 12 the float stuck in the carb and she burned... The truck is back in MI now and being re-built AGAIN by my Dad & Brother.
http://67-72chevytrucks.com/gallery/...8633&protype=1
ChevyMutt is offline   Reply With Quote
Old 03-28-2012, 01:10 PM   #5
Dieselholic92
I meant aftermarket heads. I guess I've never had stock heads on motors that I have built, so I've never had 305 heads on a 350. They have always been sort of aftermarket head
Amateur mechanic
Old 03-28-2012, 02:29 PM   #6
SSC's76
No No
SSC's76's Avatar
sounds like a good little build should run good. I've used
the 305 heads alot there can be issues with compression and detonation but they work well
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-28-2012, 03:42 PM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
There Is an increase in compression. But less flow for the bigger cam. Just get some small chamber sbc or 202 heads. 305s have horrible flow. The only gain with 305 heads is the increase in low end torque. A good set of heads will keep port velocity down low which will keep your torque an still have enough flow up high and add power.
What you should look into is some vortech heads they will get you to where your going fast
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-28-2012, 09:41 PM   #8
86 K-10
86 K-10's Avatar
^^ what he said...too bad you've got flat-tops.
otherwise, sounds like good build. be sure to post an update...im interested in how that carb works out for you
86 K-10 is offline   Reply With Quote
Old 03-28-2012, 02:53 PM   #9
sethv
sethv's Avatar
I like having 305 heads. Makes the truck pull pretty hard when you launch it
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 03-28-2012, 03:01 PM   #10
dead civic
dead civic's Avatar
pix?
00 EBP civic SI [not stock for sure]
03' Jet black CTS {slammed on ksports}
79 C10 [real project]
POW MIA. .SMOKE TIRES NOT DRUGS.
dead civic is offline   Reply With Quote
Old 03-29-2012, 03:52 AM   #11
sethv
sethv's Avatar
I personally think you can't beat a properly tuned Q-jet. It runs circles around this Edelbrock I have on it now lol.
Holleys are great carbs though, also curious to see how it works out.
1981 K10 Scottsdale
60k miles
