03-29-2012, 08:39 PM | #1 |
Wheel Size Question.
In addition to finishing the 4x4 conversion on my 63 chevy, I'm also wanting to get my 54 chevy 3800 flat bed farm truck running and moving too. As far as I know it's all original with the stock 18" split rims. I have a set (for the rear) of 16" rims/tires that were off a 75ish motorhome. Will these fit, or do I have to find some 18" rims/tires. Any help will be greatly appreciated. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
03-29-2012, 10:41 PM | #2 |
Re: Wheel Size Question.
I'm thinking that the early one ton bolt pattern is different but may be mistaken. If the lug bolt count is the same it will probably work.
