05-06-2003, 03:40 PM | #1 |
Saving 1 truck at a time!
Ballast Resistor?
Can't seem to find it! It is supposed to be on the firewall but it is not there! This was an I-6 at birth but PO put in a 283. It has a DSOM mod for a neutral start switch (manual) and some other interesting mods. May the ballast resistor is the reason the points went south? Where is it supposed to be? Got pics?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
05-06-2003, 03:43 PM | #2 |
What year truck?? if its a 71-72 the yellow wire to the coil is the ballast resistor
05-06-2003, 03:56 PM | #3 |
'67, so it is supposed to be a separate resistor...mysteriously located somewhere. I guess I could trace wires from the hot-run side of the ignition to the coil...DOH!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 05-06-2003 at 04:22 PM. |
05-06-2003, 07:55 PM | #4 |
Designated Grumpy Old Man
Stllookn, With the key on what is the voltage on the positive side of the coil. It should be around 9 volts. The wire is a resistance wire. If someone has replaced it get a ballast resistor for a 56 chev and mount it some where out of shight.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
05-06-2003, 08:27 PM | #5 |
Fabricate till you "puke"
The ballast (resistor wire) , is a white cloth type wire.... the yellow wire gives full battery voltage under eng cranking only(yellow & white are together @ the coil, & yellow runs to the solenoid). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-06-2003, 08:56 PM | #6 |
huh?
Yeah, what oldiron and crazyl said, my 67 panel didn't have a ballast resistor, it had a white cloth resistor wire. As does my 68. They were both I-6 trucks in the beginning.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
