trans line fittings.
Does anyone know what I need for tranny fittings on my 4l80e to go to -6an?.....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: trans line fittings.
97 & up 4L80E http://www.sweetperformance.com/prod...&productId=496 The fitting with the extention on the end goes in the rear port. All LS 4l80Es are this style.
91-96 4L80E http://www.sweetperformance.com/prod...&productId=480 Whatever you do, DO NOT use NPT taper pipe fittings, The are straight pipe thread called NPSM, Some companies try to pass 1/4" NPT off as the correct fitting, You need 1/4" NPSM. |
#3 | |
Home Built '87
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
![]() Join Date: Jan 2007
Summit has these also...cheaper, too.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
ok....so what are they called, or what am I asking for when I go to the parts counter?
Home Built '87
Do you know the Summit product number by chance?
I couldn't find them with a quick search.
or russel? or mr gasket?
#8 | |
They dont seem to have the 97 & later 4L80E fittings, The summit brand -6 to 1/4 NPSM for all other GM transmissions is really well priced. The later 4L80E fittings from Sweetperformance are priced for a pair at $18.00 I doubt you will find these "special" fittings for less. |
Home Built '87
http://www.ebay.com/itm/6AN-4L80E-GM...0351e2&vxp=mtr
Called them directly and he referred me to his eBay store...
#10 | |
