04-04-2012, 10:10 PM | #1 |
Help please! 250/454 swap
I am new to the site. I have a 1972 Chevy C10 step side with a 250 6cyl and Saginaw 3 speed. I am having a 454 rebuilt and it will be about 500hp. It will be overkill for cruising but it will not be raced. I have some questions.
1. I have no idea about the motor mounts or stands. Will my originals work? If not what will I need? 2. I have headers. Will they work or will I need stock exhaust manifolds? 3. I think I need a much larger radiator...3 core? What year and size truck would I search for when I am looking? 4. I have been told that the old three speed Saginaw will mate up and would be easiest, but will not last long if I get into the throttle at all. A friend gave me a rebuilt turbo 400 but it's out of a 4x4. Do I need this tranny and can it be adapted? 5. Coil springs... I assume that I need heavier duty springs. Correct? It's already really mushy. The added weight will not help. Which ones should I get? 6. This truck supposedly had a 4:30 rear end. Is this way too low for cruising around? I am sure it would tach high at 70 on the highway. Thanks in advance for your help Dan Posted via Mobile Device |
04-05-2012, 12:34 AM | #2 |
Re: Help please! 250/454 swap
Sounds like a cool build! I'll try to help
1- You need BBC motor mounts and stands, also they(stands) should move forward one hole on the frame rail. 2- Depends on what the headers are from/for. There seems to be a few issues with headers and manual trannys(clutch linkage) hitting the #7 header tube on sbc idk about bbc. I would imagine the same for bbc? 3- Radiator: bigger the better with a bbc especially, try to find a 4 row. 4- Saginaw will work great, untill you start it. Really if you must have a manual trans you should start looking for a 4spd Muncie M20/M21/M22. or shell out the big bucks for an aftermarket OD 5/6spd trans. 5- Probably a little more squishy, idk there 6- 4.30 gears! well with no overdrive that will be some nasty rpm without overdrive. Cruising may be fun but you would be slugging along on the highway going 55 at 4k rpm. (depends on tire overall diameter of course) Thats my 2 cents anyway...
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-05-2012, 05:31 PM | #3 |
I am a Referee of life.
I agree.4 row radiator (Mine cost about $200 @ Advance)requires a minor mod and new mounts,any BB vendor should have the mounts/cushions.The springs are 40+ years old,your call.
For an around town cruiser,I would keep the gears and go OD. I personally would keep the 6 and build something lighter if I wanted fast,but that's just me.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-05-2012, 08:53 PM | #4 | |
Def need new springs just dont w Know which to get?.? Posted via Mobile Device
1970 Chevelle SS 1986 Jeep CJ-7 |
04-05-2012, 08:54 PM | #5 |
Thanks 67c10rustbucket, that's good info.
