Old 04-06-2012, 07:55 AM   #1
66fleetside
66fleetside's Avatar
Cool Freeze Plug repair with engine in Truck?
A major set back after getting engine running, antifreeze pouring out the bell housing!! In the quantity that flowed out I am thinking it is a freeze plug. I have a 62 parts truck and see that the floor is removable around the bell in the cab. No such luck in the 66. Can a plug be installed pulling the trans, clutch, bell? Is there enough room to drive a new one in? How easy is it to put a plug in. Can you pop it in with a wood dowel and a mallet and is there even enough room to do this?
66fleetside is offline   Reply With Quote
Old 04-06-2012, 08:17 AM   #2
fasteddie1964
fasteddie1964's Avatar
Re: Freeze Plug repair with engine in Truck?
I've never done it, but I would think once you remove transmission and bell housing you should have enough room.
Friends don't let friends drive Fords
fasteddie1964 is offline   Reply With Quote
Old 04-06-2012, 10:03 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
might be easier to pull the engine, if your plug went because of rust, you might want to change all of them, the others might not be far behind of this one..
Old 04-06-2012, 03:26 PM   #4
hop sing
hop sing's Avatar
xxx2 from experience
hop sing is offline   Reply With Quote
Old 04-06-2012, 06:37 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Yep!! Pull the engine and replace them all.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-06-2012, 06:52 PM   #6
padresag
all 3 of them in the back can be replaced in the truck. just depends on whether or not which is easier for you. designated driver is the best way to install them. just be sure you drive it in square and not damage an edge if you are not using a driver of sorts. check the plugs on the side of the block too
ron
padresag is offline   Reply With Quote
250 freeze plug, 6 cyl.
