4 speed to a th400 auto..please help
I've searched the faqs and forums but never found anything clewr especially for the 73-87's ..does anyone got a list of what I will need all together? I just need some help I would love to swap out the old granny low 4 speed for a th400 while ky engines out.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
Re: 4 speed to a th400 auto..please help
I'm doing a 350swap. I got a brake pedal, column shift column, and had to switch the tailshaft so I could go to a single driveshaft. You can also cut your front diveshaft but you will need a slip in yoke. Then tranny lines and a cooler or radiator for auto transmission. I might have missed something but I know I'm close.
I want your clutch setup( pedals bell housing etc.)
Posted via Mobile Device |
Remember the electric kick down switch, wiring and cooler lines if you find a parts truck. If you remove the clutch pedal can you see what it stops against. I have a manual and my pedal is coming up way too far.
1963 chevy shortstep 327 1965 c60 292 2007 Ram 3500 5.9 cummins |
