04-09-2012, 04:48 PM | #1 |
How to change a tranny
Special tools needed, a walkthru would be great. Its a 98 stock 5.7 vortec engine, auto trans is slipping mostly in daytime when its hot outside, seems strange.
Does the motor have to come out to do trans swap? Thanks for the advice. Posted via Mobile Device |
04-09-2012, 04:50 PM | #2 |
Re: How to change a tranny
No
04-09-2012, 05:00 PM | #3 |
Its a Truck Thing......
Jackstands are nice, trans jack = easy on you.
Do you want step by step instructions? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
04-09-2012, 05:35 PM | #4 |
04-09-2012, 05:55 PM | #5 |
Here we go, someone will add if I miss something. This is for a 2wd I assume.
1. Jack it up and place on stands 2. Drain old fluids 3. Remove driveshaft 4. Unbolt torque converter from flexplate/flywheel this also requires you to remove the access cover to get to the bolts (you may have to remove starter) 5. Unhook shift linkages and speedo wiring along with big plug on the passenger side 6. Unhook cooler lines 7. Remove trans crossmember if it can be unbolted, if not unbolt the rear mount 8. Unbolt from engine 9. Take it down All this can be done if exhaust isnt in the way, if it is, then you have to get the exhaust out of the way. You will need a big screw driver to turn the engine while you get the converter bolts out. 2wd's = easy 4wd's = long day Smitty
04-09-2012, 06:13 PM | #6 | |
04-13-2012, 03:08 PM | #7 |
yep pretty much summed it up. 2wds are easy!
04-13-2012, 03:46 PM | #8 |
To ad to 7..to get tha crossmember out..place ig floor jack under tha trans pan to take tha pressure off it so you can slide tha crossmember out..but make that tha last step, cause when you do that she is fee to come out...you make have to pull tha dipstick tube.. also being a rookie.have anothet set a hands there..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-13-2012, 05:09 PM | #9 |
You will want to support the engine to keep it from tilting back too far and breaking your distributor cap. Don't forget to unplug your battery before you even put it on jack stands. Better to be safe than sorry.
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB Last edited by 1425956; 04-13-2012 at 05:10 PM. Reason: edit trans type, later saw it was a 98 truck. |
04-15-2012, 01:18 PM | #10 |
If your using a regular floor jack find something flat and sturdy to place under the fluid pan to keep from putting a hole in it. Double check that you have unhooked all you wires. That will turn you day into a bad one real quick. Atleast it did mine.
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS |
