04-10-2012, 07:25 PM | #1 |
Remove steering column in order to remove left inner fender
Do I need to remove the steering column for this? Looking to strip front end for now. Cab later, that way I can drive out of garage to clean the front end up. If anyone has pics id be appriated
04-10-2012, 07:43 PM | #2 |
Re: Remove steering column in order to remove left inner fender
There's a removable filler panel around the inside of the rod that allows the inner fender to be removed without removing the column.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-10-2012, 10:15 PM | #3 |
oh darn Thanks, saw it and though the inner panel just had a hole in it with a rubber type gasket to seal out stuff. Kinda feel dumb but of well. The only question not asked is the stupid question!
