Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-13-2012, 10:16 AM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Shop power
I was just looking thru some of the shop tips and realized,there's not a lot of electrical.I thought it might be worthwhile to mention elect power.
Most have 220 in their home or shop,or do they?Many times the 220 power is actuall 208 especially in older power grids.Same holds true for 3 phase.It doesn't make much difference on some equipment,but it can cause problems with Air compressors and pressure washers and maybe others.Using 208 to power a 220 device will cause a higher amp draw and heat the wiring and fuses/breakers,sometimes causing trips/blown fuses or not even letting the equipment run.
I'm just mentioning this so that you check actual voltage when considering new equipment,might save you some headaches.Most equipment can be had with either but if you don't know.......
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-19-2012, 06:09 AM   #2
Number21
Number21's Avatar
Re: Shop power
The only places that have 208v have three phase power, and you'd know if you have 3 phase. (like my shop) The rest of the American grid is 240v nominal, if you aren't within a few volts of that, most likely you have a problem.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 04-20-2012, 02:46 AM   #3
Sub-versive
Boss Hogg
Sub-versive's Avatar
Re: Shop power
This.
Modern times, what was called 220V, is actually 240V +/-. Most power companies haved bumped the voltage to help account for voltage drop, increased usage, without replacing all the wiring.
If you have 208V, without it being 3 phase, you have some problems.
RIP El Jay
2015 Subaru Outback 3.6R Limited
2002 Chevy Trailblazer LS 2WD
Originally Posted by dammitmitchell View Post
....wear your adult diaper when you go out to play.
Originally Posted by Shane View Post
I am tard.
Do, or do not, there is no try
Sub-versive is offline   Reply With Quote
Old 04-19-2012, 09:44 AM   #4
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Shop power
I believe power companies are required to be within 5% higher or lower than 120/240 at your transformer. Electrical equipment is commonly designed to operate at 230 or 115 volts plus or minus 10%.
110/220 is the old standard and is no longer used. 120/240 is the standard the power companies use. 230/115 is the standard that equipment manufacturers use.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
