Old 04-13-2012, 10:57 AM   #1
doodah man
doodah man's Avatar
Best tool for cutting factory vent holes?
So, I'm installing a Vintage Air system sometime in the next couple of months, and I'm trying to get all the tools and whatnots lined up. I want to use factory vents.
I've searched on here and found the template for the holes, but I'm not sure what's the best tool to make them. Since it's a round hole on through a curved surface, I'm worried I might get into trouble with a hole saw. Some guys over at GarageJournal recommended an air nibbler but I don't think I'll have room for that. I was also thinking about one of these bits in a drill or dremel:
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 04-13-2012, 11:27 AM   #2
HeavyD
HeavyD's Avatar
Re: Best tool for cutting factory vent holes?
Is the interior fairly complete aka nice? If it is still in the build stage there are many a/c dashes posted for sale..might be easier just to weld in the new one with the holes already done? Just a thought..
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 04-15-2012, 08:39 PM   #3
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
This is an interesting thought. How hard would this be to do? How would you go about doing it? I am planning the same Vintage Air project, but my dash was butchered up with holes and the radio mount cut out by the PO.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-15-2012, 10:58 PM   #4
4xshort
4xshort's Avatar
I'm also considering converting my non a/c cab to a/c. I have been looking on the for sale forum and the uncut a/c dashes come up alot. To me the outer vent holes don't look like a perfect circle is that just because of the curve or are the holes not a perfect circle?
1971 Chevy shortbox 4x4 made in Canada
4xshort is offline   Reply With Quote
Old 04-16-2012, 09:43 AM   #5
MARKDTN
I used a jigsaw and a long blade and just took my time. The outer ones cover well, the center one not so much.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-13-2012, 11:31 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
I used a hole saw- just have to keep it straight. The vents will cover any small imperfections, but don't let it slip too much. Cut the center with a dremel...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-13-2012, 11:37 AM   #7
AirSpeed
AirSpeed's Avatar
I've used hole saws on curved surfaces without issue, the only thing you would need to do is use a longer pilot bit so you can cut the hole squarely with the flat surface of the dash. If the the pilot bit is to short the saw edge will touch the curved section next to the gauge panel before the pilot bit can keep the saw centered.
AirSpeed is offline   Reply With Quote
Old 04-13-2012, 11:55 AM   #8
doodah man
doodah man's Avatar
HeavyD: It's still pretty (see pic below).
You guys that used hole saws. Do you know what size to use? Is the diameter equal to the diameter of the smaller part of this part?
And, thanks.
1972 C-10 Deluxe
350 V8 - 350TH
Old 04-16-2012, 02:49 PM   #9
67lowered
And, thanks.
I think I used 1 1/2", then a little filing to get it to fit. If you can get a variable speed drill, then just go slow, oil helps and shouldn't screw up the paint. As said already the lip of the vent does cover a hole a little.
If you do a search, you can find posts about welding in a dash, looks like a lot of work instead of patching holes, but I haven't done it
67lowered is offline   Reply With Quote
Old 04-16-2012, 03:17 PM   #10
doodah man
doodah man's Avatar
Do you mean a 1 1/2" hole saw? I looked at the factory vents I have and the part that goes through the hole is about 3 1/2" diameter.
1972 C-10 Deluxe
350 V8 - 350TH
Old 04-16-2012, 09:44 PM   #11
67lowered
I gave you wrong info, the side vents I have are 2 1/2" hole, I got them from vintage air
Old 04-13-2012, 12:49 PM   #12
Eddie H.
Eddie H.'s Avatar
If the cab is stripped with nothing flamable in it, a plasma cutter. If not, a rotozip tool or dremel with a sheet metal cutting bit, a hole saw, or a body saw will work.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 04-13-2012, 05:41 PM   #13
cleszkie
cleszkie's Avatar
I cut out holes in my dash for factory A/C vents. The absolutely best way to do this is with a pneumatic reciprocating saw with a fine metal cutting blade. You start by drilling a hole big enough to stick the saw blade through and then go to town. This saw will cut nice smooth curves and leave a nice edge without scaring up the surrounding metal. There is no better way to do it. Period.
cleszkie is offline   Reply With Quote
Old 04-13-2012, 06:29 PM   #14
1972trucks
i drew the template on drilled holes all the around it cleaned it up with a dremel. It took about an hour a hole but i did it that way because the dash was just painted and dint want to get the paint hot. I was worried about doing but take your time and you will be ok and the vents will hide imperfections
1972trucks is offline   Reply With Quote
Old 04-14-2012, 07:49 PM   #15
57larry
hole saw, take your time
57larry is offline   Reply With Quote
Old 04-14-2012, 08:51 PM   #16
pickupman
pickupman's Avatar
small air saw, recipricating
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 04-15-2012, 04:32 PM   #17
chopnchaneled
chopnchaneled's Avatar
Used a hole saw with mine, like above a long pilot drill and go slow.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 04-15-2012, 05:16 PM   #18
john
member #16
john's Avatar
I did mine with fresh paint too. cut templare out of shoebox like cardboard and bored with a 1 1/4" hole saw then put rotary file in a die grinder and went to town. Only took 20 min. per hole going slow around the edge to keep things cool.
john is offline   Reply With Quote
Old 04-15-2012, 05:41 PM   #19
Boog
laying low
Boog's Avatar
Way back when there were no dremels, sawzalls, plasmas, etc I put vents in dad's 72 by marking the area to be removed then drilling a number of small holes around the edge of the opening then cuttting through them by using a rat tail file. Yeah it took quite a while. Be proud of the tool options you have today.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-15-2012, 06:58 PM   #20
JCD
JCD's Avatar
One of the biggest problems in using a hole saw on a curved or angled surface is the side pressure you put on the saw..
Here's a tip.. drill your center hole first, and remove the drill bit center from the hole saw.
Replace it with a piece of smooth metal rod the same diameter as the drill bit.
As you apply the side pressure to cut the odd shaped dash panel, this keeps the hole saw centered over the hole and won't drift off center, or side cut the hole like a drill bit would.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
