Old 04-14-2012, 04:22 PM   #1
70-Chevy
-Chris
70-Chevy's Avatar
Rear Drum Brake Help
Hey guys,
I swapped out my original rear for a brand new, powdercoated rear with new axles, locker, gears, etc, etc.
The right rear wheel assembly is missing the bolt that the two brake pads pivot on that is right above the cylinder. (See Picture - The picture isnt mine......just found it on the internet)
Does anyone know where I can get one of these and the nut that is on the backside as well? I already tried to use my old one, but after beating on it and heating it up, Im convinced its not coming off.
Thanks for the help in advance!
Chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 04-14-2012, 05:30 PM   #2
68SHORTBOX
68SHORTBOX's Avatar
Re: Rear Drum Brake Help
I have a couple of spare backing plates that have the bolt in question still attached will see what kind of shape they are in and try to get one off if you think that you could use it. When I did my 68 we could not find a supplier who carried replacement parts for it. Free just cost of the ride.
68SHORTBOX is offline   Reply With Quote
Old 04-14-2012, 05:30 PM   #3
cdowns
cdowns's Avatar
i've never had any luck removing them either
you could just take that old backing plate you have get it powdercoated and use that
Old 04-14-2012, 06:43 PM   #4
gysgtc
If 68shortbox can't get the one he has off I will see if I can get you one off of a spare I have.
gysgtc is offline   Reply With Quote
Old 04-14-2012, 07:35 PM   #5
gysgtc
I just took one off of the front spindle. You would have to get a nut for it because on the front it screws into the spindle. I don't want to jump ahead of anybody so let me know if you need it and I will send for free. Wayne
Old 04-15-2012, 12:40 PM   #6
68SHORTBOX
68SHORTBOX's Avatar
Looked at the backing plates and was wondering what the nut on the rear of your backing plate looks like? There is a washer type keeper on the front of the pivot to keep it from working loose. The rear nut on the two spares that I have may be diffrent than on the 70. The front pivot bolts screw into the spindle they tend to come out eaiser than the rear. Applied some PB blaster so we will see how it works out.
Old 04-15-2012, 01:22 PM   #7
ChevyNewb
ChevyNewb's Avatar
Dealing with this issue now, I don't believe the rears come off. Check on the other side and there are 2 hex heads that attach to your wheel cylinder. I didn't notice until I actually looked at the new wheel cylinder. We almost mangled the piss out of before we stopped to look...
ChevyNewb is offline   Reply With Quote
Old 04-15-2012, 02:02 PM   #8
gysgtc
This is the one out of a front spindle.
Old 04-15-2012, 04:58 PM   #9
70-Chevy
-Chris
70-Chevy's Avatar
Shortbox, I need the bolt and nut. does you have both? send me a PM and we can work out payment and shipping.
Thanks guys!
Old 04-15-2012, 05:01 PM   #10
68SHORTBOX
68SHORTBOX's Avatar
Got one loose and all it took was a whole lot of heat and a big A----s wrench and hammer. You might have to dress the surface of the bolt where the brake shoes pivot but it's not perfect. Let me know where to send it.
Old 04-15-2012, 10:13 PM   #11
68SHORTBOX
68SHORTBOX's Avatar
Have both and the lock washer. Just need to know where to send it!
Old 04-16-2012, 07:36 PM   #12
70-Chevy
-Chris
70-Chevy's Avatar
All, thanks for the help. Shortbox has the nut and bolt that he is going to send my way. Once again, this board has saved me!
Thanks again!
Old 04-17-2012, 05:06 AM   #13
gysgtc
That's why I love this board. Everyone on here always helps out.
