Old 04-14-2012, 10:24 PM   #1
Beaumont@
Help identifying front suspension parts on a 1970 C10
As the title says I need a little help identifying a few parts on a 1970 C10. I just bought the truck and the previous owner couldn't tell me much. It has had a front disc brake conversion done but not sure which years parts were used. Its not aftermarket. I have to replace the steering gear its worn out but may just replace the entire steering system as well. The outer tie rods for sure.
What I know:
-All the ball joints have been recently replaced upper and lower
-The brake hard lines run on the rear of the crossmember
-The steering gear has this part # 7802644
-The rotors are 1 1/4 in wide
-The front brake hoses are too long
Any help would be appreciated the front brake hoses are way too long and look like sh!t. I need to fix this. As well the steering column has been shortened by the looks of it. Why would someone do this? I would like to fix this as well.A welded steering shaft doesn't fill me with confidence. I have attached lots of pics. Any advice would be appreciated.
Beaumont@ is offline   Reply With Quote
Old 04-14-2012, 10:38 PM   #2
Beaumont@
Re: Help identifying front suspension parts on a 1970 C10
More pics
Old 04-14-2012, 11:55 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
My guess would be 71-72 parts on your original '70 crossmember.
The hoses are the 73-87 version.
The only way to know for sure,... is to identify the upper balljoint or the outer tie rod.
These 2 parts are specific to either 71-72 or 73-87 spindles.
The a-arms are definitely the 63-70 or 71-72 version.
Keith
Convert to disc brakes.
Old 04-15-2012, 01:23 AM   #4
Beaumont@
Curious why the 73-87 front brake hose would be used if 71-72 parts were used? Are the brake hoses interchangeble for those years?
Old 04-15-2012, 10:42 AM   #5
lolife99
lolife99's Avatar
73-87 hoses are 100 times more available that the "2-year only" 71-72 hoses.
But the front components could also be 73-87 parts swapped into the older a-arms.
The a-arms and crossemember are era correct,... but with a balljoint change,... they "could" be 73-87 spindles, rotors, and calipers.
And I'm with you on swapping out that welded steering column.
Keith
Old 04-15-2012, 11:20 PM   #6
Beaumont@
About that steering column what would be the best way to fix it? Can I just replace the inner shaft that runs through the column? Its a new 1970 tilt according to the previous owner. Its mystery why they would butcher it but it is what it is.
Old 04-16-2012, 08:57 PM   #7
Beaumont@
Anyone know who sells the internal steering shaft for a 1970 chevy tilt steering column?
Old 04-15-2012, 01:39 AM   #8
Beaumont@
I am not familiar with these trucks I am new to them so I appreciate the help, getting closer to solving this. A real pain in the @$$ no doubt .
