Old 04-15-2012, 03:28 PM   #1
desertnick69
desertnick69's Avatar
Frame and ALL ???
Ok I know this is more than likely a repeat question. What is the best paint to use on my frame and can I us the same thing on the A arms, drag link, idler arm etc??? And where i can get it in Phoenix, Az.?
desertnick69 is offline   Reply With Quote
Old 04-15-2012, 04:05 PM   #2
gysgtc
Re: Frame and ALL ???
POR-15. Hard as beavers teeth
gysgtc is offline   Reply With Quote
Old 04-16-2012, 03:24 PM   #3
mtnbikeman
MasterSeries Coatings. Like POR 15 but less expensive. Im am doing my frame and suspension right now. I got the first coat of silver primer on last night. It works real well and flows out nice.
mtnbikeman is offline   Reply With Quote
Old 04-16-2012, 04:35 PM   #4
desertnick69
Where do you find it.
Old 04-16-2012, 05:01 PM   #5
ffk
ffk's Avatar
i used eastwoods chassis paint.......
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 04-16-2012, 06:14 PM   #6
GMtrucknut!!
GMtrucknut!!'s Avatar
I just finished my chassis and In used KSB coatings satin black . It looks great and it is hard as can be,prep is rather tedious though.
GMtrucknut!! is offline   Reply With Quote
Old 04-16-2012, 08:38 PM   #7
mtnbikeman
I ordered direct from them. Masterseriescoating.com. There customer service has been very good so far. The prep is similar to other products, clean, clean, clean, acid etch and then apply.
Summit racing carries rust bullet which I don't think requires a special base coat
Old 04-22-2012, 01:57 PM   #8
desertnick69
Did you get the ACID Etch from masterseriescoating.com also or from some where else? I am getting ready to order the Mastercoat Permanent Rust Sealer, and AG111 Topcoat so that i can paint by midweek.
Old 04-22-2012, 02:30 PM   #9
Rob68c10
One of my friends swears by rust bullet. Not sure if you already prepped your frame or not.
Rob68c10 is offline   Reply With Quote
