Old 04-16-2012, 11:28 AM   #1
afcamaro
afcamaro's Avatar
Static Drop Questions
I have been searching high and low and cannot figure out a direct answer. I have a few questions. I have a 70 SWB truck and want to lower it.
In the summer Im always pulling a trailer and do not want to bottom out. I want it the lowest I can go, without bottoming out. I was thinking a 3/4 drop or 4/5 drop. Id even do a 2/3 drop if I had to. Which one would be the best route to go since I will be towing?
What all would be needed for a 3/4 drop, 2/3, and 4/5 drop. I keep reading people are c-nothing at 5 and 6" drops in the rear and that is not something I want to do at this point. Do the shocks really need the relocation brackets and an adjustable panhard bar?
What is the lowest I should go with just ordering a spring in front instead of a drop spindle?
Most likely it will have 20" wheels but the 18" are not out of the question.
Any pictures would help greatly. Thanks.
afcamaro is offline   Reply With Quote
Old 04-16-2012, 12:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Static Drop Questions
3/5 drop is the lowest spring drop.
This will require drop shocks, rear shock relocator and adjustable track bar.
(no notch).
A 3/4 drop would require:
1) drop shocks up front.
2) Stock rear shocks and brackets.
3) Stock track bar.
A 2/4 drop would let you use stock front shocks.
Just remember,... these drop springs are "x" inches lower than new replacement stock springs,...
NOT your sagging 40+ year old springs that are on the truck now.
So a 2" drop spring might only net you 1" of additional drop.
Keith
Convert to disc brakes.
Old 04-16-2012, 10:08 PM   #3
afcamaro
afcamaro's Avatar
ok so with the 3/5 drop, that will even the truck out correct? Just asking because so many trucks on here have a 2 inch more drop in the rear and still have a small rake. Might be their wheel configurations.
Would I still be able to tow with a 5" drop in the rear? will I need to take the rubber frame bumpers off? Thanks
Old 04-19-2012, 04:06 AM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: Static Drop Questions
I cut my rear rubber even with the frame so it just hits the rubber before the frame. Then I added the helper air bags and it works great. The ride is outstanding.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-19-2012, 09:39 AM   #5
afcamaro
afcamaro's Avatar
Alright thanks, What drop do you have on your truck? Do you know how much travel room in the rear you have?
Old 04-19-2012, 02:23 PM   #6
Andy4639
Old member
Andy4639's Avatar
Check this out. This is a video of my truck running 20" wheels all around.
With the shock relocator and helper air bags.
