Old 04-18-2012, 07:43 PM   #1
gimmy 64
hard brake pedal
ok guys i have a question that i can't seem to figure out. i did the disc brake upgrade to my truck using ece dropped spindles and brakes. i used the original rebuilt power brake booster. and new master.brakes have a hard pedal and don't stop very well. i don't think it is the booster because it worked fine before. any suggestions?? thanks
gimmy 64 is offline   Reply With Quote
Old 04-18-2012, 08:40 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: hard brake pedal
Did you change the brake hoses? Also did you clean the rotor after installation?
62 Barnfind is offline   Reply With Quote
Old 04-18-2012, 09:09 PM   #3
gimmy 64
new hoses , brakes bled good. it's not combo valve checked it with light --not on?
Old 04-19-2012, 11:17 AM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
It probably wouldn't hurt to tee in a vacuum guage to verify that you have vac at an idle.
Also look at your check valve to make sure that you are capturing the vac. that you develope.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-19-2012, 12:10 PM   #5
gimmy 64
it has a steady 16hg at idle a little low but should be good?
Old 04-19-2012, 04:39 PM   #6
A.T. RockDriller
That should be plenty...
You might check the check valve...The plastic 90% thing that pushes into the rubber grommet and has the hose on the other end...If you pull it out of the hydro-vac ....you should be able to blow into it..(toward your intake manifold) and you should not be able to suck through it.
I hope it's that simple for ya...
By chance, when you bolted yer new master cyl. onto your H-Vac....was the plunger engaging the piston prior to the housing seating against the booster....so that as you tightened the nuts the MC began to stroke befor it was tight...?
Just shootin in the dark.
Good luck...
Les Hunter
Old 04-19-2012, 08:04 PM   #7
FreakyMalo
FreakyMalo's Avatar
Sounds like the master bore diameter might be wrong for the rear wheel cylinder bore diameter.. or the calipers. Too-small slave cylinders can give a hard pedal.
Do you feel the booster kick in if you start the engine with the brake pressed?
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 04-19-2012, 08:16 PM   #8
gimmy 64
yes forgot to add that .. pump brakes let vacume out start engine pedal drops maybe 1/4 in. but you can feel it.
Old 04-19-2012, 09:04 PM   #9
FreakyMalo
FreakyMalo's Avatar
You might check the master cylinder specs and see if the drum side is for 1-inch wheel cylinders.
66 Carryall
my photos
