Old 04-18-2012, 10:45 PM   #1
XXPainterXX
Will I need a proportioning valve
I am building a 1966 short wide that my Grandpa bought basicly new and had a question. The truck was special ordered with power brakes and I am converting it to disc front and rear hopefully this weekend and was wondering if I am going to need a proportioning valve as well
XXPainterXX is offline   Reply With Quote
Old 04-18-2012, 10:53 PM   #2
jocko
jocko's Avatar
Re: Will I need a proportioning valve
yes, you will. if you were just converting to a dual res master cyl (for safety) with drums all around still, then no, BUT since you're planning a disk/drum, you'll need to balance - and if disk/disk, it would be appropriate for adjustability. Bottom line - if any disks, use a prop valve. If all drums (and using an "all-drum" master cylinder - like an original 67 drum/drum mc, for example), the proportioning is built into the master cylinder itself by the phasing of when the circuits are pressurized - and this requires that the correct line be hooked up to the correct ports on the mc (i.e. front brakes brake line to the rear port and rear brakes brake line to the front port (counter-intuitive)).
So, yes And make a note that CaptainFab sells a nice bracket to mount stuff. http://67-72chevytrucks.com/vboard/s...d.php?t=347484
Old 04-19-2012, 12:41 AM   #3
GWs62
GWs62's Avatar
How does one go about getting such a nice bracket??
When was the last time you did something for the first time?
We never really grow up, we only learn how to act in public.
GWs62 is offline   Reply With Quote
Old 04-19-2012, 01:16 AM   #4
jocko
jocko's Avatar
or, go to the thread in my post above, then click on CaptainFab and select Private Message to send him a note
Either way will work.
Old 04-19-2012, 01:04 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
^Post in his thread that you are interested in getting his nice bracket.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-21-2012, 01:29 PM   #6
bama63
bama63's Avatar
i used an adjustible prop valve plumbed into the rear line and used the 72-76 corvette dual master and it cost $42.00 compared to $90.00 for the combo valve and its way more adjustible to get the perfect balance
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
