Anybody running a big block with th400 and 3.55 gears?
I'm about to do some upgrades to my rearend in my 68'. Right now I have an open 3.73 setup. I'm cruising on the highway with normal flow of traffic at 3500 rpms. This is really not a problem besides drinking up the gas lol...but if I'm going to change to a limited slip set up I might as well change gears if I'm going to do it while I'm in there. I've been thinking about running 3.55 limited slip or 3.42's what you guys think and list you mods if you could and what rpms you are seeing.
Here's what I have... 1968 SWB 502 H.O. Crate Engine Minor head Work still has 2.19/1.88 valves Bumped the Compression up a bit over 9.5:1 Howard's Hyd Roller cam-Duration:235/241(ADV 288/294)Lift:618/618 LSA:112 Air Gap Intake with Holley 950HP DUI ignitionHooker Comp Headers 2" primaries 3.5 collector3" Exhaust Race Built Stage 3 TH400 2800 stall 3.73 gears open carrier Loving the way my truck is performing but the open rear is killing me! |
Re: Anybody running a big block with th400 and 3.55 gears?
I would run a 3.08 or even a 2.73 to let that big block live a long and healthy life. The 3.55 will not help much to lower the RPM's. I have a 402 in my 56 Chevy truck with a 400 trans and a 2.73 rear end from a 79 Seville and it works great. You could also have a 700R4 built up for the big block and it would work the best. I have a 4L80 in my 68 crew cab with a 454 and 3.73 gears which works great but also have 35" tires on it. I am running about 2000 RPM at 70 miles an hour and getting about 12 miles to the gallon with a lifted truck.
![]() ![]() Join Date: Jan 2011
DIA of your rear tires?
I swapped the 3.08 gears in my 71 to 3.55 and not impressed, wish i had gone with 3.73
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#5 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
3.07 was stock for BB powered C/10 trucks. My suburban would get 17mpg freeway @65 on L78 tires. That was a pretty much stock but tuned engine with a good air cleaner. With a 502 I'd imagine you are doing a lot better than the 402/210hp. So if you want mileage step up to a 2.73 or consider an o/d trans. swap or a Gear Vendors O/D.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
[QUOTE=Racie;5324138]I'm about to do some upgrades to my rearend in my 68'. Right now I have an open 3.73 setup. I'm cruising on the highway with normal flow of traffic at 3500 rpms.QUOTE]
I had the same problem but went a different way as I really wanted to keep the high speed starts but still get better mileage and less noise on the freeway. My Truck is running a 572 BB with a TH 400 trans giving the following ratios 1st 2.48 2nd 1.48 3rd 1.0 The diff is a 4.10:1 posi coupled to a gear vendors 0.7:1 or 1:1 overdrive The tires I use are 285/60R17's with a 30.46 diameter which gives final drive ratios of 5.94 in OD or 8.94 @ 1:1. that's 2340 rpm @70 mph in OD or 3340 RPM @ 1:1 Much quieter in OD but i can still burn the rear tires all the way through first and second. |
#8 | |
#9 | |
[quote=Fitz;5325768]
Posted via Mobile Device Last edited by Racie; 04-22-2012 at 06:52 PM. Reason: Spelling |
