04-22-2012, 10:28 AM | #1 |
Rear mount tank vs rear cross sill?
On the really low trucks that are putting in rear mount tanks, I assume the tank is sitting higher than the frame and interferes with the rear cross sill. What are you guys doing to mount the back of the bed / modify the cross sill?
Pics are worth a thousand words... |
04-26-2012, 07:27 PM | #2 |
67-72 parts collector,…
Re: Rear mount tank vs rear cross sill?
Anyone?
04-27-2012, 01:57 AM | #3 |
If you haven't bought a tank look at http://www.porterbuiltfabrication.co...quipped-Trucks
04-27-2012, 02:09 AM | #4 |
C/10 junkie
Subscribed
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
04-27-2012, 05:19 PM | #5 |
Boyd Welding makes some nice aluminum tanks. Not that the Porterbuilt isn't, as I offer that as well, but the Boyd is a little more affordable depending on your budget. The Boyd tank hangs down below the frame rail about 2.5", but this can be modified if you want it tucked up higher. Just need to adjust the size of the tank and/or clearance the bed brace. You end up seeing about 1.5" of the tank when you are standing behind a lowered truck.
As they come, it doesn't require any cutting of the bed or anything, and is a bolt-in deal. Just depends if you go with the bed fill version or side fill. Hope this info helps. Boyd Tanks - $349 (carb version) |
04-27-2012, 09:41 PM | #6 |
As a few have mentioned the Porterbuilt tank, his is a prime example of a tank that would require modifying the rear cross sill. Just wondering what people have done...
04-28-2012, 01:57 AM | #7 |
I think nates comes with the rear cross member bar shown if not he sells them.
05-01-2012, 04:14 AM | #8 |
Is there another option to this for those of us with rear, frame mounted air tanks? I have a 5 gallon air tank in the rear, and two compressors in front of that, plus my horns. Is there a tank that could be mounted in the bed? I know I can do a fuel cell in the bed, but I want something more secure and safe. PS - I have a stepper.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
05-01-2012, 09:27 AM | #9 |
A popular option is to raise the entire bed floor so that sits several inches higher, clearing the tank and other components that have been packaged underneath.
Not everybody likes the raised floor look, and if you didn't want to go that route, your stuck cutting the cross sills for clearance. Nate Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-01-2012, 10:03 AM | #10 | |
05-01-2012, 10:11 AM | #11 |
Our tank does not interfere with the rear most cross brace for the bed.
05-01-2012, 11:36 AM | #12 | |
05-01-2012, 12:16 PM | #13 | |
I assume you are talking about the "bed floor" crossmember. Do you have a wood floor or a metal floor? Like Nate said,... your going to have to modify the bed crossmember at the very minimum. (Or even raise the entire floor). It all depends how high your tank is above the frame rail.
05-01-2012, 11:45 AM | #14 |
I thought we were talking about the rear most cross-brace where the bed bolts to the rear of the frame.... this does not come in contact with our tank.
From there forward.... it's another story. I guess I am not quite clear on what information you are looking for. In order to run a tank that has 15+ gallon capacity, and have adquate ground clearance on a truck that is capable of laying frame... Some trimming will be needed. I will check back in later today and see if I can offer any more suggestions/information. Nate
05-01-2012, 12:20 PM | #15 |
The factory blazer tanks will work back there,... but not on trucks that lay frame.
(unless raised above the frame rails) 5/7 static dropped trucks and bagged trucks with air bags installed in place of the stock coil springs can utilize the blazer tanks in the stock location.
05-01-2012, 12:33 PM | #16 |
Yes the cross sill on the bed floor of a 63-66 truck with a wood bed. I fully understand that the cross sill will need to be modified, that was the whole point of this thread from the beginning LOL... to see what guys have done to support the bed / how they modified it.
