Old 04-22-2012, 10:06 PM   #1
lvin4jc
What's the difference between these two low beam headlights?
I need to replace a low beam headlight on my 1963 and I guess I don't know what the difference is between the two listed on the lmc website page 107 http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=107
What's the difference between part number 36-0253 and pn 36-0260?
Tia,
Joe
1963 GMC 1500 2wd 4spd BB 305 V6 "Remmy" the rat rod
lvin4jc is offline   Reply With Quote
Old 04-22-2012, 10:51 PM   #2
AngryPirate
AngryPirate's Avatar
Re: What's the difference between these two low beam headlights?
Just a guess here, but one is halogen and the other is just plain old incandescent.
AngryPirate is offline   Reply With Quote
Old 04-22-2012, 11:18 PM   #3
lvin4jc
Not sure, when you add it to your cart one says halogen and the other says sealed beam, but afaik that's the same thing..
Old 04-22-2012, 11:59 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
They are both sealed beams. As noted in the previous post one is a conventional sealed beam and the other is halogen. This isn't new tech, halogen sealed beams have been around for at least 20 years. The halogens have two key features – they are significantly brighter than non-halogen sealed beams, and they burn out faster than any other type of headlamp on the market. Every time my truck leaves the garage the headlights are on. While conventional bulbs can last several decades, even running all the time, halogen bulbs only last a few months with continuous use.
For many years I ran halogen sealed bulbs in all four positions until I just got fed up constantly replacing them. Now I run conventional non-halogen bulbs in the low beam positions and halogens in the high beam positions. Since my high beams don’t get used very often, they last a couple of years before burning out.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
