Old 04-23-2012, 02:23 PM   #1
55reasons
55reasons's Avatar
64 Shortbed Fleetside/ project "VVRV" / Vintage Volkswagen Recovery Vehicle
This will be a rather slow build due to my constant travel schedule.
Purpose-built C10 to haul my VW around, sometimes with my '50 BMW motorcycle, and/or recover vintage VW's for resale or restoration.
The plan as it stands:
Dually rear end narrowed to fit inside the bed with no flares.
Bagged all the way around.
10-lug bolt pattern oversized disc brakes w/ 22.5" semi wheels (Alcoa) cut down to 22" to run passenger tires.
No fancy paint, just patina, raw steel, clear coat and rubber.
Manual tranny, and a V8.
Fuel tank relocation.
Started with this 64 C10 that I picked up in Twentynine Palms, CA from cru_zn_29 on April 13th with an extra GMC hood.
I liked the shape of the GMC hood lights and openings, so I sprung for the extra hood and swapped it out as soon as I got it home.
The interior has some rust in the lower front cornersthat needs repaired, but the seat frame and springs are in great shape.
55reasons is offline   Reply With Quote
Old 04-23-2012, 02:40 PM   #2
55reasons
55reasons's Avatar
Re: 64 Shortbed Fleetside/ project "VVRV" / Vintage Volkswagen Recovery Vehicle
So, this past weekend, I decided to fire up the compressor and take the DA sander to the original hood and see what was under the thick tan paint so I would know what the rest of the truck was going to entail.
The pass side front corner of the hood had, what looked like a huge dent, with a large chunk of body filler in it. To my pleasant surprise, I pryed out a chunk, and the whole patch came out. It was a fiberglass fill, and the metal under it was as clean as the pure driven snow. The dent that it was covering didn't bridge the body crease, so it's an easy fix.
I don't plan on using ANY body filler on this project. Even sheet metal replacement, if required, won't be skimmed over. What you see it what you get with this one. Nothing to hide.
I moved on with the sander and the more I worked on it, the more I really liked what I was seeing as the original paint started coming through.
By the end of the day I decided that I was going to do the whole truck like this. Primer, bare metal and all, will be cleared over as is.
I'm already having second thoughts on using the GMC hood now that I see the OG paint on this hood.
I'll pound out dents by hand the best I can, and fill the hole for the hood ornament and the holes in the bed for the hooks that I've already removed as well when I get to them.
I'm really liking this look so far.
I'll continue this process on the rest of the sheet metal.
For the inside of the cab, and the inside of the body panels, I'll walnut shell the metal and coat it with a quality rust preventative as I move along.
Old 04-23-2012, 08:10 PM   #3
Dinos63
chevy only
Dinos63's Avatar
nice find!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-24-2012, 02:32 PM   #4
55reasons
55reasons's Avatar
I came across this Clear Epoxy that is advertised as being designed for exactly this kind of application.
Has anyone ever used, or known anyone who has used, this particular product or a similar clear epoxy like it for coating over bare metal?
This claims to completely seal the surface. ie; no rust development under the clear unlike a traditional clearcoat finish that is prone to seepage and peeling.
http://www.squeegskustoms.com/products.html
Also, on a separate note, I was in for a rude awakening yesterday when I went to the PPG dealer in Palm Springs yesterday only to find out that PPG DX330 and all of the other DX line of products for surface prep are now ALSO illegal in the state of CA. Total bummer.
Now I gotta head to Phoenix this weekend just to get the PPG products and hopefully pick up the Clear epoxy while I'm there as well.
Old 04-24-2012, 04:06 PM   #5
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Patina, old chevy truck, old VWs...what's not to like?? I'm subbed to this one. Sounds awesome.
Old 04-24-2012, 06:40 PM   #6
55reasons
55reasons's Avatar
Ordered the SATIN Clear Epoxy from squeeg's kustoms a little while ago.
He claims there is no need for a adhesion promoter for the bare surface when using his product.
So, in order for anything interesting to happen this weekend, I'll need a portable blaster, about 50lbs of walnut shell, a ventilation hood, some wax and grease remover, and a quart of two part black epoxy primer for the underside of the hood.
Hopefully I can land all this before Saturday and get an idea how the rest of the truck will look after practicing on the hood with some new products.
Old 04-24-2012, 11:48 PM   #7
monolith
Zero Albedo
monolith's Avatar
Nice! Cant wait to see this one! I opened the door to my shop this morning and was greeted by a 69 bug that wasn't there yesterday. My buddies new project.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 04-24-2012, 11:57 PM   #8
55reasons
55reasons's Avatar
Sweet....
Here's a pic of my RHD 55 Oval and I taken a few months ago in, you guessed it, Yuma, AZ.
Old 04-25-2012, 12:14 AM   #9
monolith
Zero Albedo
monolith's Avatar
Nice!
This is the lil guy that was smiling at me as I opened the door.
Baz
68 Dodge Charger
Old 04-25-2012, 12:41 AM   #10
losthope
losthope's Avatar
Good looking truck and nice oval! wish i had a older bug ,I have a 73' but still fun just doesnt look as cool as the older ones..
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 04-25-2012, 07:59 AM   #11
coulter
coulter's Avatar
dude i really like ur plans for this build!!! cant wait to see how this turns out
btw ever thought bout putting a 12 valve cummins in it? that would be really sweet too.. but way more expensive
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 04-25-2012, 11:39 AM   #12
55reasons
55reasons's Avatar
Funny that you mention it! That was my original plan.
I decided that for the sake of weight on the front bags, cost, and my total ignorance when it comes to diesel engines, that I would be better off sticking with a small block.
I really dig the idea though, and maybe in the future, the diesel could be the round 2 revival of this truck.
Old 04-25-2012, 09:14 PM   #13
coulter
coulter's Avatar
ya they would have to be some strong bags to hold that up.. You just cant beat those old 12 valves though.. super good fuel mileage and the best throttle response ever!!! o ya they last forever to
anyway good luck on ur build!! im gonna keep an eye on it
Old 04-25-2012, 09:31 PM   #14
55reasons
55reasons's Avatar
Thanks for the good wishes gents!
Got the walnut shell blasting gear today with 50lbs of walnut shell to go with it.
Hopefully the Clear Epoxy top coat gets here before the weekend so I can knock at least this first panel out as a lab experiment.
I think I'll just use a black epoxy primer on the inside of the panels and spray the clear epoxy right over the black primer.
K.I.S.S. method in full effect.
....after I ditched the diesel idea, I really wanted a 09+ 5.7 liter VVTI Tundra drive train in it. I ditched that too based on cost. I have to keep reminding myself that this is a budget build and simplicity is the name of the game.
Old 04-26-2012, 02:18 AM   #15
55reasons
55reasons's Avatar
From what I have dug up so far, a factory assembled Toyota 5.7 with a factory warrantied TRD supercharger makes:
507 hp @ 488 lbs used for about $3,500.
A crate Vortec Supercharged Chevy 350 with aluminum heads in stock trim weighs in at:
383 hp @ 511 lbs new for about $5,500.
My calculations are as follows:
Toyota: 507 hp @ $7.00 per hp.
Chevy: 383 hp @ $14.50 per hp.
Not trying to stir up a hornets nest, but I'm interested in some opinions on this. I genuinely dismissed the Toyota V8 idea based on comments that it would be too heavy and expensive. From what I can tell just surfing the internet, I was either fed bad info, or I'm comparing apples and oranges.
507 hp from a 488lb V8 for less than a supercharged crate 350 sounds to good to be true.
**edit** ....also stumbled across a website that specializes in adapting 6 speed manual transmissions to the Tundra 5.7... Somebody better talk me out of the tree!
Old 04-26-2012, 06:20 PM   #16
McMurphy
McMurphy's Avatar
Hah!
Someone else building a hauler.
Unlike me though, you have some mad, but clear plans, I cannot wait to see you pull this off.
I am tuned in, if you build I will watch!
to the site and Good Luck!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-30-2012, 12:20 PM   #17
55reasons
55reasons's Avatar
Tackled the test run on the hood this weekend.
The product from Squeeg's Kustoms is awesome to work with.
Sprayed on perfectly with a 1.3 tip on the gun.
I left the front section (turn signals, etc.) of the hood untouched. I found cancer in the front corner, and with the dent on the other side, I've decided to swap out the whole front section of the hood.
Either way, this is a good test run of the finish, while it will protect the bare metal from rusting while the rest of the body gets worked out.
If I sand through all the paint on the top of the cab and it's white under there, the whole top of the cab is going to go down to bare metal before clear. The baby blue / white combo just isn't my thing.
I'm really pleased with the hood though.
Nice satin, clear finish....
Old 05-21-2013, 01:16 PM   #18
juanz1947
rusty 66
juanz1947's Avatar
Its been a year how's the truck doing
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 05-23-2013, 12:02 AM   #19
55reasons
55reasons's Avatar
Thanks for asking!
Well the truck is still sitting in AZ waiting for me to return from Hawaii to get started on it!
Old 01-30-2014, 10:22 PM   #20
Thomashsturgill
Any updates? How has the clear coat help up?
Thomashsturgill is offline   Reply With Quote
Old 01-31-2014, 04:07 PM   #21
aggie91
I'm just glad to be here!
aggie91's Avatar
Great Start
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
