04-24-2012, 09:58 PM | #1 |
Fuel Gauge
My gas gauge will only show 1/2 tank when full even when i switch tanks. I figure it must be a ground problem. Where do these tanks ground at? I was looking underneath today and couldnt really figure out where the ground is.
87 4wd 350 |
04-24-2012, 10:11 PM | #2 |
Re: Fuel Gauge
I had a similar problem, empty was right but when I was full it only read 1/4 on either tank. My problem happen to be a bad gauge.
John 82 Chevy Silverado 350ci/TH350 |
04-25-2012, 01:05 AM | #3 | ||
Moderator
Re: Fuel Gauge
A bad ground will permanently pin the gauge at 3:00 past the F mark. Each tank has it's own ground so it's unlikely they both have partially failed in the same manner. I would make sure the tank wiring isn't squashed between the bed and the frame on both sides. If the gauge reads E correctly but 1/2 when you're actually Full then see my explanation below. If it's stuck at 1/2 and doesn't move... you have a bad gauge or sender. Quote:
When the resistor makes proper contact the needle will sweep to the full range of the gauge. When the resistance changes, from loosing contact, the needle will no longer move to the top of the gauge but bottom is unchanged. When you change the gauge out it works again because the new gauge has a fully working resistor not because the gauge itself was bad. It's possible to fix the resistor by lightly buffing the contact with fine steel wool (for corrosion) or adding washers that are slightly larger than the bottom of the retaining nuts to get by the vibration damaged contact surface. |
04-25-2012, 10:04 AM | #4 |
Re: Fuel Gauge
Thanks for all the replies guys, I will be on the lookout for a new instrument cluster. The only one of the gauges that actually works now is the temp and speedometer, witch is about 20mph off. I'll just bit the bullet and get it all working.
Thanks |
04-26-2012, 11:31 AM | #5 | |
Re: Fuel Gauge
04-26-2012, 10:30 AM | #6 |
Re: Fuel Gauge
04-25-2012, 11:23 AM | #7 |
Re: Fuel Gauge
I'll agree, I don't think that your problem is a ground. Sender or gauge itself, but it sounds like you have a plan and direction to go. Good Luck!
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
05-16-2012, 01:06 AM | #8 |
Re: Fuel Gauge
Awesome fix! Took my gauge out, cleaned up contacts on that resistor and put some dialectic grease on there and my gauge works again! Thanks Hatzie!
Posted via Mobile Device |
07-01-2012, 12:49 PM | #9 |
Re: Fuel Gauge
annnnnnddddd, now mine's back to reading 1/4 tank. Took the gauge out and put regular nuts on the resistor (push nuts had loosened) and put back in. When I turned the key, the gauge started to go to F, then about 1/2 way there it stopped and dropped back to 1/4 tank. Looks like my gauge is bad or the resistor is shot.
Anyone know if I can get the resistor ONLY somewhere? I'd like to keep my stock gauge if possible. |
07-01-2012, 02:36 PM | #10 | |
Moderator
Re: Fuel Gauge
You could try flat washers with external tooth star washers underneath. I'll check the ohm value on my good spare gauge tonite. This article has info on the color vs ohmage on vette gauges. IDK if other's any correlation to our clusters. GM didn't document this for the general public or their techs. http://www.europeancorvette.com/html/console_gauges.htm
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-02-2012, 12:28 PM | #11 | |
Re: Fuel Gauge
I am ok at soldering so will try that before I spring for a new gauge. Is this something I can get at radioshack or am I going to have to buy online? |
07-09-2012, 01:21 PM | #12 |
Re: Fuel Gauge
Soooo, tried the star washers. Still nothing. Gauge goes to 1/4 tank and stays there.
Anyone know of a source to get another resistor? If I get an aftermarket gauge will it have a resistor that will work with the stock gauge (assuming it is the resistor that is bad and not the gauge)? Can one of you electrical genius types tell me how to MAKE a resistor that would work (I can follow directions on RadioShack stuff if it's written on a 3rd grade level)? |
07-09-2012, 01:25 PM | #13 |
Re: Fuel Gauge
I appreciate your desire to keep a stock appearance, but it might be easier to buy an aftermarket gauge for Classic Parts for $50 and switch out the gauge faces. I just put the aftermarket gauge in my 83 and left it with the aftermarket gauge face, showing fill markings in icon format rather than E to F.
07-09-2012, 02:06 PM | #14 |
Re: Fuel Gauge
Found a resister for a 67-72 pickup for $10. Part number 67-04508 at www.truckandcarshop.com. That work? From what I've found all GM vehicles from 65-early 90's used the same fuel gauge (at least the guts)
07-11-2012, 12:06 PM | #15 |
Re: Fuel Gauge
Found this one and am going to try it.
http://www.ebay.com/itm/390024357497...84.m1423.l2649 From what I could find all GM cars from 65ish up use a 0-90ohm fuel gauge (and the 69 camaro does according to all the forum threads I found on the subject) so hopefully this will work..... I'll report back when it comes in. |
07-11-2012, 04:02 PM | #16 |
78K & 79C Jimmys
Re: Fuel Gauge
check the other ground for the gauge
behind it,behind the cluster where they all go to one when i changed over my idiots to gauges issues stopped
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-18-2012, 11:30 AM | #17 | |
Re: Fuel Gauge
SUCCESS! I got the above resistor yesterday and put it on the truck. For anyone searching in the future, I've attached the packaging for the resistor with the part number; W-586 which was advertised as a fuel gauge resistor for a 69 Camaro. |
07-11-2012, 04:52 PM | #18 |
Re: Fuel Gauge
Not sure what I'm looking for. My truck is an 83 so I have speedo cable, one light on the top passenger side, and a square electrical connector, and that's it. Don't see a ground wire anywhere.
If there is one, where does it ground? |
07-11-2012, 06:22 PM | #19 | |
78K & 79C Jimmys
Re: Fuel Gauge
Ground is black wire in the plug More then one Posted via Mobile Device
07-12-2012, 09:23 AM | #20 |
Re: Fuel Gauge
07-12-2012, 09:27 AM | #21 | |
78K & 79C Jimmys
Re: Fuel Gauge
thought those were stock but look about a foot back from the cluster plug un ravel the friction tape can't miss it cause it's prob got about 4 + wires together
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-12-2012 at 09:34 AM. |
