04-28-2012, 11:57 AM | #1 |
Sm 420 tranny girnding when downshifting
WHen in 2,3,4 and going to downshift it grinds and wont go in that gear, it needs to stop before downshifting. Anyone else ever experience this?
04-28-2012, 12:14 PM | #2 |
Re: Sm 420 tranny girnding when downshifting
after these years you could have some wear in there causing it, synchros plus bearings..
drain the gear oil and see how many cuttings and such that you collect ron |
04-28-2012, 12:44 PM | #3 |
I have seen that you will have these problems if your clutch doesn't release fully. Check the adjustment.
Posted via Mobile Device |
04-28-2012, 01:26 PM | #4 |
is it possible it may just because theres no sycros on the first 2 gears? Mebe sycro rings gone? I did not try to rev match, took it for a drive then took cab off, so adjustment will have to wait. Im only 18 and I just bought it so im not entirly sure what it "should" feel like. Thanks
04-28-2012, 02:35 PM | #5 |
you don't have syncro between 1st and 2nd but you do between 2 & 3 and 3 & 4. when you going up through the gears it will more than likely shift easier as everything has worn together over the years. but when you are going down in your shifting you have more than likely lifted your foot of the throttle which changes the thrust inside your trans causing the harsher d/shift
new syncros and a brg and gskt kit should put it back into good useable shape. brg and gskts may do it itself. that is why I said to drain the oil and see what comes out in the oil. that will tell you what is wearing. brass for synchros, fine gray sludge is usually brgs and chunks mean breakage. it is 50 years old. nothing lasts forever without a bit a of work ron |
04-28-2012, 02:49 PM | #6 | |
04-28-2012, 06:58 PM | #7 |
Well.... I have bad news...Very bad I would think. Let me know.. Guess I can stick my fingers in the tranny, doesent sound or look good at all. The seal is completly gone and the inside and outside is coated and baked in 1/2 inch of oil. Thought it was undercoating...
04-28-2012, 08:09 PM | #8 | |
in the picture your just taking out the torn rubber dust boot ron |
04-28-2012, 11:33 PM | #9 |
thats the bellhousing and the clutch fork hole not the trans--------------
1961 chevy K10 my build is------------61K10 build |
04-29-2012, 08:29 AM | #10 |
Thats good to hear.
My first ever build!! 1965 c10 LWB 283v8 sm420 http://67-72chevytrucks.com/vboard/s...63#post5337863 |
04-29-2012, 08:50 AM | #11 |
Six in a row makes it go...
Here's what it looks like inside. Those little teeth that aren't the big gear teeth are your synchros. They may be worn.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
04-29-2012, 11:37 AM | #12 |
i would agree - it's very likely the synchros that are causing this. You should need to be at a complete stop before downshifting into 1st because 1-2/-21 is not a synchronized shift in this trans (many 3-speeds were this way also), but that is all - the rest of the gear transitions should be smooth. If getting grinding in all gears during downshift (and not during upshift), it is likely the synchros. If you're getting it while upshifting also, then there may be an issue with the clutch not fully disengaging when you press the pedal, as was mentioned above (or could still be synchros in this case also - absence of the problem when upshifting just eliminates the possibility it's the clutch, that's all).
And concur - the pic you posted is nothing to be concerned about, it's just the clutch fork boot. The fact that it's torn and that dirty isn't the end of the world, but might be indicative that the clutch hasn't been changed in eons. Since you're going to have to go to the trouble of pulling the trans to get the synchros fixed, I'd definitely replace the clutch, pressure plate, and the flywheel (or resurface it if no heat cracks visible) while you have things apart. Hope that helps. |
04-29-2012, 11:52 AM | #13 | ||
04-29-2012, 12:02 PM | #14 | |
These guys have parts and info. I've never dealt with them, but they've been around for awhile. http://www.novak-adapt.com/catalog/sm420_parts.htm
04-29-2012, 01:24 PM | #15 |
GMC1965,
Since you're only 18 I thought I would pass along some info I wish someone told me when I was your age Never, I mean Never down shift to slow your truck down. Your transmission is NOT a Brake. Down shifting to slow the truck loads the rods Not a good thing. Down shifting to keep the truck up in the RPM band is fine, like down shifting after making a turn etc. to get your speed back up under power is OK but down shifting to slow your vehicle down is definately a bad thing. Not to mention it's a LOT CHEAPER and easier to replace brake shoes or pads than it is to replace a clutch, pressure plate, throw out bearing and have your flywheel resurfaced. Another thing I learned while replacing the trans in our company dump truck C50? I went through the passenger door with the engine hoist and pulled & installed the trans that way. I used my personal Harbor Freaight cherry picker to do it and it worked great. Just make sure you have enough chain to let the trans to the ground. I made a plate that bolts to the shifter hole and used an "Eye Bolt" dead center of the plate to raise & lower the trans into place. I still have the plate if anyone wants it for FREE just pay shipping. It might be a Little heavy though as I made it out of stainless steel. |
04-29-2012, 04:35 PM | #16 | |
04-29-2012, 12:39 PM | #17 |
clutch kit (disk+pp+release bearing) will run around $120-$150, depending on your app. Here's the oreily's page for a 66 C10 283 - (not sure what your truck is) - you'll need to know hub diameter and overall disk diameter (10.5/11/12", etc). http://www.oreillyauto.com/site/c/se...kup&vi=1321872
Fly re-surf is approx $25-$40 bucks at your local machine shop. |
04-29-2012, 04:30 PM | #18 |
Oh alright doesn't seem that bad. I was thinking it would cost me 500 or more. I asked a friend and he said its not a big job to change synchros so I guess il be doing that with him. Il get him to look to wear on anything else while im at it.
04-30-2012, 01:59 AM | #19 |
My 1960 had an granny gear 4 speed. When I pulled it out of the truck I took the tranny hump off and dropped the tranny to ground from inside. It was way too heavy to lift so I tied a rope to it and drug it out from under the truck. I bought a full rebuild kit for it but change my mind on the tranny. I still have the kit if you are interested in rebuilding yours, it's listed in the classifieds on this board.
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
04-30-2012, 07:36 PM | #20 |
Kid's Mechanic
I'm wondering how much free play you have . That is the clutch pedal travel that that doesn't do anything . If you push the clutch pedal down with your hand you can feel the free play . More than 2'' is too much .
And isn't that piece on the clutch rod on the wrong side |
04-30-2012, 07:46 PM | #21 | |
04-30-2012, 07:51 PM | #22 |
Kid's Mechanic
Pedal has to be in place to check it . Adjusting the free travel is the clutch adjustment . with out it being right it would be tough to get in gear at a standing start and make downshifting tough
