![]() Join Date: Feb 2010
wtb 6 cly. tach head
anybody have one? have extra v8 heads or cash. thanks, glen
website https://www.villagegarage.com/ truck guy in the whiskey world https://www.instagram.com/c10glen/?hl=en https://www.hemmings.com/stories/car...e-perfect-day/ |
![]() Join Date: Apr 2012
Re: wtb 6 cly. tach head
Hi, Question for you would a 6 cylinder tach read higher if installed on a 8 cylinder? The reason I ask is that my tach reads higher than the actual rpm. Are the tachometers marked 6 or 8 cyl? Thanks, Paul
maybe? should be marked on back 8 cyl or 6 cyl. i have an 8 if you have a 6.
I will have to pull my instrument cluster and see I will let you know. Unless you find one before I can get back to you.
The Older Generation
A 6 cylinder tach should read about 30% higher than actual rpm on a v8. The ink stamp should say either 6CYL or 8CYL. and if you can read it, the part numbers are.. 6CYL #6468321 ... 8CYL #6468228 There is a small screw on the back of the tach with a piece of tape covering it up. Just adjust it using another tach for reference, (both hooked up to the same engine). Sorry about the hijack, Glen... LockDoc
check it out and let me know. thanks.
I pulled it out and it's marked 8 cyl, sorry now I know. Good luck on your search. Paul
Moderator
![]() Join Date: May 2007
I have an OEM 6 cylinder tach that I will be posting for sale here on the board late tonight when I get home. It will need to be restored. I will post you a link to the ad when I list it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Moderator
Glen- Here are some pics. It needs to be restored. There are no burn marks on the circuit board, however I have not tested it. It is stamped 6 CYL on the back, it is faded and won't show up in the pic. It is easily seen when you are holding it in your hand. $100 Shipped. 6 cylinder tachs are pretty rare to come by, so if you have a nicer V8 tach, and can adjust it as Leon described above, I would go that route.
pm me before you post it. thanks. glen
67-72 parts collector,…
![]() Join Date: Nov 2002
I think locdoc meant your could adjust out the minor inaccuracies in the tach with the adjustment screws.
You would still need a 6-cylinder tach for an I-6 engine. Member 70shortfleet sells a "tach face" decal that take the tarnished look out of your old worn tach. http://67-72chevytrucks.com/vboard/s...ight=tach+face (my opinion,... $100 is a super deal, for the 6-cylinder tachs)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-29-2012 at 09:11 AM. |
i think so too. i am going to dig out some of my 8cyl tachs later and check it out.
Moderator
Glen, you have first call on it since I posted here in your thread. I priced it based on what I have seen V8 tach heads in the same condition sell for. If I had obtained it from a running truck and it was not so weathered I would price it much higher. I figure since it is for a 6 it is worth restoring. Thanks.
