leveling my c30
whats the easiest way to level my c30 dually? can i take out the thick helper leaf and like 2 leafs? i either wanna drop the back alittle or lift te front to level it. any help appreciated
Re: leveling my c30
Depends on how you use your truck. If you need to haul heavy , then I would leave the leaf springs alone and shim the front. If more interested in a smoother ride then yank a leaf spring .
I wonder if there is a leaf spring shackle kit that lowers instead of raises? |
Re: leveling my c30
it doesnt tow much maybe wood and will probally haul some cars around and dirtbikes/quads. i just dont like the noose diving lol
Re: leveling my c30
you could use drop shackles, that will give you about 2"
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Re: leveling my c30
nose diving? that sounds like it needs shocks.
Is the front end low all the time or when braking? |
Re: leveling my c30
i mean like how it sits lower in the front from the factory. is there anyways i can lift the front up like 3"?
Re: leveling my c30
ya lift springs would lift you up...
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE |
Canadian Trucker
Re: leveling my c30
He's got a C30... 2wd.
On a C30 dually, I'm not sure if they make lift spindles or coils for that truck.
![]() 2020 Silverado Trail Boss - 6.2/10spd |
Re: leveling my c30
i found a set of 3" lift coils and i was gonna use a 2" spacer and yes its 2wd
Re: leveling my c30
Did you have any luck lifting the front of the truck with springs?
