Different low ratios in np205s?
I thought that all 205s had 1.96:1 low ratios but I have one out of a 75 3/4 ton, 27 spline version and the tag says 2.05:1 ratio. The tag on my 4 speed 205 in my 77 1/2 ton with a 4 speed says 1.96 ratio. Has anyone ever seen this before? Just was curious when I saw it, kind of looks like they stamped it wrong or something.
Re: Different low ratios in np205s?
heres a pic
![]() Join Date: Mar 2003
All the ratios are the same. some knucklehead at the plant stamped the tag wrong.
Thanks, thats what I figured because it looked like a hair less than 2 turns of the input shaft when I turned the output shaft once but my eyeballs also aren't that accurate
Probly a friday afternoon shift put it together...
