Old 04-30-2012, 11:21 PM   #1
low79fx
My attempt at PS
OK after extensive review and study of Capts PS application heres my attempt at it. Sorry Capt I know yours is tried and true but I just had to give it a try.After all it was your design that nudged me to give it an attempt.All cutting was done on band saw with a lot of messaging with 4" grinder and file. Spacers cut from plate steel and trued on drill press which improvised as vertical lathe. Still need to weld spacer to PS plate.Will update as I progress on install.
low79fx is offline   Reply With Quote
Old 04-30-2012, 11:51 PM   #2
Blue Heeler
Blue Heeler's Avatar
Re: My attempt at PS
You forgot the beer can in the backround
Blue Heeler is offline   Reply With Quote
Old 05-03-2012, 10:24 PM   #3
low79fx
OK as I progress in my fab up of parts I thought,it would be cool to be able to pull column without having to pull steering wheel. So I came up with this. Use intermediate shaft from the later truck from rag joint to column.My thinking is if I ever want to upgrade to newer tilt keyed column the shaft will be in place.
Old 05-08-2012, 10:28 PM   #4
low79fx
Slow progress.
Old 05-19-2012, 11:03 PM   #5
low79fx
OK going to mount PS box hopefully pics will tell the story.
Old 05-19-2012, 11:08 PM   #6
low79fx
Gearbox mount continued.
Old 05-23-2012, 06:40 PM   #7
low79fx
Man I have to say after driving this thing for 2 days with PS it is like night and day.What a difference.
