05-01-2012, 02:03 PM | #1 |
Brake booster
I am thinking about updating my brake system. I have a 69 chevy 4x4. It was a 1/2 to, but I upgraded to 3/4 axles. The master cylinder is the original with no brake booster. So I have manual brakes I guess. I would like to add a brake booster, but I am wondering what will fit. I looked at a booster for a 69 and it looks to big. I think it will hit the steering column and the oil dipstick coming out of the engine. Is there a smaller booster or am I just looking at this wrong?
1969 4x4 Nothing beats a good rock drill and some dynamite |
05-02-2012, 01:41 AM | #2 |
Re: Brake booster
Im not too 4x4 informed but as far as I know any booster from a 69 will work, be sure to get the entire mechanism and you may need to change the master cylinder.
05-02-2012, 04:29 AM | #3 |
Collector of Projects
Re: Brake booster
Do your 3/4 ton axles have disc brakes?
Do you want it to look original? Whats your budget? The master cylinders for power vs. non-power brakes are different. I would buy the CaptainFab (board member/vendor) bracket HERE, add a newer style booster and the correct master cylinder. |
05-02-2012, 10:40 PM | #4 |
Re: Brake booster
Yes the front axle has disc brakes, no I'm not really concerned if it looks original, more concerned with functionality, and my budget is tight at the moment.
05-03-2012, 02:07 AM | #5 |
Re: Brake booster
If you have auto column shift the Captain Fab bracket will not work. You'll need to check the local junk yards or the classified ads here for an assembly. You'll need the brackets and the distro block.... I will suggest a new/reman booster and master for a 72 K20 from a local parts store. Make sure the master gets bench bled to get all the air out..
Here is an assembly here on the board.... |
05-03-2012, 10:36 AM | #6 |
I miss this truck.
Re: Brake booster
Be sure to get the rod from the pedal to the bracket when you get your bracket. Ask me how I know. They are different between power and non-, and can be hard to find separate from the bracket.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
05-03-2012, 04:52 PM | #7 |
Re: Brake booster
Random thought: on the cars I've had there's a different hole drilled into the brake pedal for assisted vs. manual (you need more leverage with manual, so its further away from the pivot point). Not a big deal but a minor detail to check when you do the conversion.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
