Old 05-02-2012, 08:28 PM   #1
Handfull 54
Handfull 54's Avatar
What coil springs for a 54 Chevy with aluminum heads.
I have a 54 Chevy with a Fatman front end. It uses all Mustang II parts. I got a kit and put on bigger brakes from a Chevelle. I bought Mustang II V8 springs and cut 1 coil out. The ride was kinda rough but after 500 miles the springs have settled and now my bottom A frames are north of my rack about 2 inches. Fatman told me to buy new V8 springs and do not cut them. Does anyone have any experience with springs that they have used? I just want it so sit low but i hate the ride. Are dropped spindles the answer. Any help appreciated. I have the mustang top and bottom A frames with all new bushings and new ball joints and tie rod ends etc. and the strut rod also. The engine is a Big Block with Aluminum Heads and Intake.I know the answer is out there. Thanks guys.
Handfull 54 is offline   Reply With Quote
Old 05-03-2012, 11:32 AM   #2
robnolimit
robnolimit's Avatar
Re: What coil springs for a 54 Chevy with aluminum heads.
The lower A-arm should be flat, or level to the road at ride hieght. If you want it lower than that, use drop spindles. '78 MII V-6 springs work well, but don't cut them. The V-8 spring may be needed with the BBC even if it has aluminum heads. Run a front sway bar.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 05-03-2012, 12:15 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
One thing that you didn't mention was shocks. Once you have done what Rob suggests, take a look at your shocks too. A nice set of billet adjustables would be icing on the cake.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
