05-03-2012, 08:14 PM | #1 |
oil bath breather restoration? new filter hair available?
I pulled out the horse hair (I think that is what it is) in my oil bath breather so i could have it powdercoated and was wondering if anyone else has ever done this and what did you use in place of it? I did keep the old stuff but it looks fairly dirty and when i removed it the hair broke down into small pieces that the engine may suck up now. is there maby a special foam or replacement hair to make it like new again? Rod.
05-04-2012, 09:05 PM | #2 |
Re: oil bath breather restoration? new filter hair available?
Some small engines have a kind of foam air cleaner i think. Anyone have any ideas?
Posted via Mobile Device |
05-04-2012, 10:32 PM | #3 |
I was thinking foam as well. I'm sorry, other than that, I wouldn't have a clue what else you could try.
Keith |
05-04-2012, 10:51 PM | #4 |
I wonder what kind of foam to use? Where to look for it?
05-04-2012, 11:49 PM | #5 |
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
05-04-2012, 11:50 PM | #6 |
05-05-2012, 03:21 AM | #7 |
would a steel whool work for a replace meant. some ss stuff like a pot scrubber is what I was thinking of ?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
05-05-2012, 03:51 PM | #8 |
you can buy a roll of stainless steel wool. it is packed fairly tight and would be hard to get back in there but might work. similar to pot scrubbers. is there a certain air flow cfm or something that an air cleaner needs so the engine breathes good?
05-05-2012, 04:03 PM | #9 |
stailness steel
http://www.ebay.com/itm/Stainless-St...item483f15152d what do you guys think. I would think tht this would not be flamable but would try burnbing a small spot before using it. |
05-05-2012, 04:05 PM | #10 |
What?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-05-2012, 05:16 PM | #11 | |
05-05-2012, 05:41 PM | #12 |
What?
I never took the OE fiber out.
I just soaked it in simple green, then rinsed it clean. The metal mesh I use as noted above, is what I put it the oil itself and stand it on its edge around the inside of the filter. The oil wicks itself up the metal mesh, and adds extra filtration for the dust. I don't know if this was original, but it's been that way as long as I can remember in my original set up. So I just continue to it, and I do see it helping since it does get dirty.
05-05-2012, 07:19 PM | #13 |
Mine had the matrial already gone so i decided to powder coat it.
05-05-2012, 08:07 PM | #14 |
Just my opinion, but I wouldnt use steel wool if you shake it alot of small pieces fall ouy of it. On the rigs we use "filter blankets" they are available at Aklands. They come in all thickness and sizes and would be available locally. Plus they are made for air filters so it would be safe. Hope that helps.
1971 Chevy shortbox 4x4 made in Canada |
05-05-2012, 10:48 PM | #15 |
i will have to go check them out . thanks for the help 4xshort
05-05-2012, 10:52 PM | #16 |
Son of a gun
Tractor supply company carries replacement material for oil bath air cleaners.
Bill BEATERS ARE NEATER |
05-06-2012, 12:58 AM | #17 |
Would copper mesh work like they used on the older harleys i wonder?
05-06-2012, 11:30 AM | #18 |
Air cleaner wire mesh - still used in agricultural tractors.
http://www.just8ns.com/catalog/produ...roducts_id=522 Nine bucks. Best regards, Ray |
09-14-2013, 12:50 PM | #19 |
10-20-2013, 11:37 AM | #20 |
11-30-2013, 02:35 AM | #21 |
Nothing yet, my project is on hold for a few months. I'm on a military deployment. I was hoping you would find a solution
12-12-2013, 03:06 PM | #22 |
I am going to use one of these. http://www.just8ns.com/catalog/8N-96...r)-(2-REQUIRED) or http://www.steinertractor.com/ABC422...th-air-cleaner. They both look the same. I am going to get this done after xmas so ill let you know how it goes.
09-15-2013, 05:28 PM | #23 |
I was thinking about this last week but haven't used anything yet. More ideas welcome.
03-22-2014, 09:14 AM | #24 |
Wow, Chewy that looks fantastic! I had pretty much given up on using the oil bath. But yours looks better than new. As soon as I return from my deployment I'll give you an update.
