Old 05-05-2012, 09:44 AM   #1
jackson
49 cab shackles
anybody replace the rubber bushings. my cab looks like it sits a little low in the back. could it be the shackle bushings
jackson is offline   Reply With Quote
Old 05-05-2012, 10:29 AM   #2
mr48chev
mr48chev's Avatar
Re: 49 cab shackles
It could be. the whole cab mount kit is only about 20 dollars from most vendors. The measurements between the cab and the frame are in the Assembly manual and I thought I had a copy on Photobucket but couldn't find it and I am at work.
Old 05-05-2012, 11:05 AM   #3
mknittle
mknittle's Avatar
Re: 49 cab shackles
Isn't that always the case
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-05-2012, 05:40 PM   #4
mr48chev
mr48chev's Avatar
Re: 49 cab shackles
Here is the page for the rear cab mount and shackle. It shows .76 of an inch between floor and frame.
Here is the page for the front mount
I hope that helps.
The shims between the upper shackle bracket and the floorboards is a new thing to me.
Old 05-05-2012, 05:54 PM   #5
jackson
Re: 49 cab shackles
I hope that helps.
just changed my bushings and it had the shim
