Old 05-09-2012, 09:37 AM   #1
8door
Not too old to learn
How best to install chrome trim in windshield rubber
As title sez. I tried doing a search but apparently did not describe the
question correctly ???
I started with the rear glass and placed the rubber on the glass first and got the trim on all but last 10 inches and could go no further.
Here is what I did,started with long bottom strip , then up one side then across top and that is the place it became difficult to open the slot.
So what am I doing wrong ? Will windshield be as difficult ?
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 05-09-2012, 09:41 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: How best to install chrome trim in windshield rubber
I always put the rubber on the glass first. You will find it much easier if you have at least one other person to help. Two is even better...
It also depends on what brand of rubber you have. I always use Precision brand.
LockDoc
Leon
Old 05-09-2012, 09:55 AM   #3
8door
Did the rubber on glass first, and using Precision brand.
Should I start putting the trim on in a different spot ?
Old 05-09-2012, 12:37 PM   #4
8door
Lockdoc I got it done, I made it more complicated than it is .
Old 05-09-2012, 01:51 PM   #5
biggestjohn
What did you do different this time?
biggestjohn is offline   Reply With Quote
Old 05-10-2012, 12:14 AM   #6
8door
Slowed down and looked closer at what I was doing.
Simple as that !
Old 05-09-2012, 09:58 PM   #7
LockDoc
LockDoc's Avatar
Glad you prevailed.
LockDoc
Leon
