Old 05-10-2012, 01:20 PM   #1
c10327
c10327's Avatar
1970 c10 2wd - manual to power steering ??
I have a 1970 c10 that came with manual steering an having an issue with pit man arms ? the manual Pittman arm wouldn't fit the new power steering box as the splines shaft was different . so I bought a power steering pit arm an it fits the new box but now were it bolts to the drag link the shaft is different size than the old manual shaft . the shaft is a little to small to tighten up properly ? do the make a shim or is the another pit arm for this kinda swap ?? any help would be great
c10327 is offline   Reply With Quote
Old 05-10-2012, 02:16 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 1970 c10 2wd - manual to power steering ??
I used a 68 PS pitman arm on my 68 with a later model(Unknown year but o-ring fittings) box.Everything bolted right up and worked correctly.I was told to use the pitman arm that works for the front steering since the PS Pitman arms are the same on the box end for all years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-10-2012, 02:31 PM   #3
c10327
c10327's Avatar
are all ps pit arms the same for the 67-72 2wd truck ? an if you knew a part number of the 0ne you used on yours? or vendor name the one i have is for the 70 c10 ps box which fitts the box but is not a tight fit in the drag link when tighten down
Old 05-18-2012, 01:37 AM   #4
Frijolito1988
This says it should be the same.
Group by same.
*60-66 Manual
*60-66 P/S
*67-72 Manual
*67-87 P/S
What kind of PS pump do you have ? What truck did you get it out off ?
Frijolito1988 is offline   Reply With Quote
Old 05-18-2012, 01:37 AM   #5
BigBlockNuts
Call Classic Performance Products in Anheim CA 714-522-2000. Ask for Jeff! He'll be able to assist u!
BigBlockNuts is offline   Reply With Quote
Old 05-18-2012, 06:09 AM   #6
c10327
c10327's Avatar
it was a quality control issue with advance auto parts !
, the first pit arm was boxed wrong , so the manager ordered me another one same part number # 3days later it show up at the store, I go to open up the box an wa la a tie rod end falls out !! WTF not a happy camper . enuf f n around . I called Moog Monday got some specs matched it up with the old pit arm an order a Moog part k6131 fit like a glove ,
the only difference between the manual pit an the power pitt arm is were it fit's on the steering box the splined hole is bigger for the #k6131 ..
tried to save a few buck$ on the steering conversion an bought a drive works value line part DW-6131 Bad idea. the 3rd attempt was Moog an the manager discounted a $104.99 part down to $47.99 which helped
lesson learned don't spare $$$ on front end parts always buy the best .. as these cheap parts the these stores sell are just that cheap an a waste of your TIME .
Old 05-18-2012, 07:43 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Gentlemen , this is not a classified section of the board . If you have something to sell it must be in a classified
powerdriver 1958 is offline   Reply With Quote
