Old 05-11-2012, 11:54 AM   #1
michael bustamante
michael bustamante's Avatar
stiff,bouncing around suspension
Ok i took my 67 longbed on its maiden voyage since i dropped it. In the front I replaced my lca`s with some good stock ones with good bushings and ball joints, did the disk brake conversion and cut 7/8 of a coil off good stock springs. and shocks are stock size monroe sensa-tracs. In the rear i bagged it with Dominators, viair and valves and shock relocators. the bed hasent been put back on yet, thats this weekend.
now the rear i am still finding the right pressure to soften the ride so thats no big deal there. but the front has me bouncing off the seat a little. any suggestions to smooth the ride out?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2012, 12:30 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: stiff,bouncing around suspension
Did you use drop spindles also?
How close is the rubber snubber on the lower control arm?
You might need to trim those down or replace them with shorter ones.
Keith
Convert to disc brakes.
Old 05-12-2012, 12:33 PM   #3
Dano69c10
Dano69c10's Avatar
do you have 6cyl springs or v8 springs up front? When I had 6cyl springs in my v8 truck the ride was horrible, it seemd like my front end was jumping off the ground everytime I hit a bump.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 05-13-2012, 02:40 PM   #4
cdowns
cdowns's Avatar
what type of tires and rims do you have// traditional 15 or 16 rims and tires give good ride quality by air pressure adjustment
the less the sidewall the bigger the rim the less ride quality is what i've found
