Old 05-11-2012, 11:32 PM   #1
chance65c20
lower ball joint help!!!!!!!!!!!!!!
ok so i am trying to remove lower arms from the spindals. i got the driver side of easily but the passenger side is being a b****. I am using a pickle fork and mini sledge. I have soaked and lubed with penetrating oil. i have been fighting this for a while now and about to give up. Im a strapped for cash and was wondering if you guys had any ideas????
chance65c20 is offline   Reply With Quote
Old 05-11-2012, 11:38 PM   #2
allaboutchevelles
allaboutchevelles's Avatar
Re: lower ball joint help!!!!!!!!!!!!!!
I just took mine apart last week and had trouble with my drivers side. I couldnt get my pickle fork to fit right on the ball joint. I ended up using a big chesel and wedging it in there and poped it a few times with the sledge and got mine off. its aggervating, good luck.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 05-12-2012, 12:15 AM   #3
XtechX
XtechX's Avatar
Smack the spindle knuckle where the lower ball joint goes through the spindle. Hit it HARD!!!!!! If you keep beating it, it will come off. I thought mine would never come off, but it finally did. I read on here to hit it and it still wouldnt budge, I needed to hit it harder. Dont worry you wont brake that area of the spindle. Several good whacks and it will come apart.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 05-12-2012, 12:31 AM   #4
Captainfab
60-66 Nut
This is what I always do.
Old 05-12-2012, 12:34 AM   #5
chance65c20
thanks guys i have tried that already. i swear this ting wont come out. i just cant give up it has to come out eventually right?????
Old 05-12-2012, 12:39 AM   #6
XtechX
XtechX's Avatar
I mean HIT IT, get mad!!!!!!!!!! ....lol. Itll come apart.
Old 05-12-2012, 01:12 AM   #7
64shortbox
64shortbox's Avatar
I actually bought a 10 LB sledge hammer and cut the handle down to be about the same length as my 5 LB hammer. A few good whacks with a cut down 10 LB sledge hammer did the trick for me when I was tearing mine down.
64shortbox is offline   Reply With Quote
Old 05-12-2012, 09:26 AM   #8
scotts62
One day...
scotts62's Avatar
Pickle fork will just tear up the ball joint especially if you have to go back together with it for some reason.
I like doing ball joints just for the reason to smack the crap out of something!
Scott
93 crew cab build
Project 62
Old 05-12-2012, 10:23 AM   #9
rideblue00
rideblue00's Avatar
I made my own tool to take out ball joints. It will do upper and lower. This can be made in any home shop with a welder and peice of pipe. I used a 3/4" bolt. If you do it with pipe, you need one 3/4" nut to weld on. Its about 4 inches in length. Start with a long enough pc of pipe and cut to fit. Also I put a short pc of pipe on the bolt head so it wouldnt slip off sideways.
rideblue00 is offline   Reply With Quote
Old 05-12-2012, 11:11 AM   #10
chance65c20
rideblue00
exactly how do you use that tool you made????
Old 05-12-2012, 05:01 PM   #11
Rusty one
Rusty one's Avatar
Wondering that myself
Rusty one is offline   Reply With Quote
Old 05-12-2012, 06:54 PM   #12
64shortbox
64shortbox's Avatar
I'm sure rideblue00 will chime in but it's actually very simple. One end of the tool sits into the upper ball joint stud and the other end sits in the lower ball joint stud. Once the castle nut is removed or loosened if you're removing both ball joints you simply "unscrew" the bolt end and it will "JACK" the ball joint loose. This works GREAT if your ball joints are good and you want to save them like if you're replacing control arm bushings, springs etc.
Old 05-13-2012, 07:21 AM   #13
rideblue00
rideblue00's Avatar
Thats right! I used hexstock so i could put a wrench on it. But like my post said you can use black pipe and a bolt and nut. It also saves my knuckles by not needing a hammer.
Old 05-12-2012, 07:03 PM   #14
maxwoof
If you can put tension on the joint with a long bar first, then smack the side of the spindle, that alays worked for me. I would have somebody stand on the bar, and then smack the spindle with two hammers at once.
maxwoof is offline   Reply With Quote
Old 05-12-2012, 08:16 PM   #15
forestb
forestb's Avatar
You might want to try a threaded rod with a deep nut on the end (like the one in the previous photo) that you could put in between the spot where the upper ball joint connects to the spindle and the end of the bolt on the lower ball joint in such a way that when you loosen the nut it will expand the length of the rod and push the ball joint through. Or if you have a small enough bottle jack or a jack for a newer car that might work also.
I know this is a rabbit trail but can you buy replacement rubber covers for the ball joints and outer control arms if they get a tear in them? The ball joints and outer control arms themselves are fine.
forestb is offline   Reply With Quote
