Old 05-13-2012, 04:59 PM   #1
peglegs
peglegs's Avatar
87 4x4 rear end id
im replacing the spider gears in my rear end so far this is all the info i have
1987 1/2 ton 4x4 305/350
glove box tag #GT4= 3:73 rr. axle gear ratio
10 bolts
no tag anywhere
i dont believe its positraction ( then i wouldnt need the spiders) & rather not take off the cover as yet, thought i would find that on the glove box sticker
did search here for 10 bolt id, rear end id nothing came up. From the internet is its a 10 bolt corporate
id like to order the spider gears but not totally sure if i have all info thanks
Happy Mothers Day to all the ladies
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 05-13-2012, 11:00 PM   #2
walkerscott
Re: 87 4x4 rear end id
RPO G80 check out your glove box
walkerscott is offline   Reply With Quote
Old 05-14-2012, 12:29 AM   #3
peglegs
peglegs's Avatar
not there what is that # for?
Old 05-14-2012, 02:46 AM   #4
walkerscott
RPO code are the three digit letter number combinations found on your glove box tag
so G80 is for limited slip..
your rearend is 28 spline 8.5" gm 10 bolt. pretty sure it started in 1988 and later versions are 30 spline, trucks and vans vin series ckv versions may not be though
Old 05-14-2012, 03:20 AM   #5
peglegs
peglegs's Avatar
ty walker scott, i did deciferd all the rpo #s i guess the reason i would like to be sure its posssible, as in any multiple owner vehicle, it could have been changed ill go on what i have here thank you very much for your time & expertrise
