Gas Tank Stinks
On my new 1966, drove it today and the whole cab stinks like gas, like eye bleeding smell. Tank seems original and a bit lose in neck filler, like it needs a clamp or something.
If I changed to a new tank inside the cab, what are my expectations? no smell of gas from in cab tanks or what? How bad do yours smell Brad |
![]() Join Date: Sep 2011
Re: Gas Tank Stinks
Provided the tank is solid, you only have two points where it will leak. From the fuel filler neck or the sending unit area. Actually, the sending unit can leak from the gasket or from the union where it meets up with the hard line. Tighten up both of those areas and you'll be fine.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
![]() Join Date: Nov 2010
Re: Gas Tank Stinks
Mine had a strong smell of gas for awhile but i replaced my sending unit since it was needed anyway and a new filler hose and i havent smelt it since.
Re: Gas Tank Stinks
I dont have any smell from mine.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Re: Gas Tank Stinks
Thanks. I will try all of the above and may even just put a new tank in as I do not wish to relocate it.
1963 c10 please send me a PM about wipers Brad |
Re: Gas Tank Stinks
I would replace the filler tube, 2 hose clamps and the sending unit gasket 1st. That's only $10-12 in parts, which should fix your problem. If the old tank isn't leaking, I wouldn't replace it...personnally. The repops are Chinese garbage and you may find more problems down the road from a cheap replacement tank.
