Gas gauge?
My gas gauge quits working but then if I take a hard enough turn it works again for a few minutes what could cause this?
Posted via Mobile Device |
#2 | |
![]() Join Date: Feb 2011
Re: Gas gauge?
Paul Posted via Mobile Device
1969 C/20, 307, 4-speed, rusty with manual steering and brakes! |
Active Member
![]() Join Date: Jul 2007
Re: Gas gauge?
Agree. ^ If all the wiring is good and not shorted and the gauge checks good, then the sender unit needs to come out of the tank.
With the key on, take the single brown wire off the sending unit on the tank and touch it to ground. The needle on the gauge should read empty. If you unplug the sender wire from the fuse panel the gauge should go towards the full position. Another possibility is the sending unit may be stuck or float/cork leaking and not working. Here's the full info on testing the sending unit. http://www.6066gmcguy.org/Electrical-02.htm |
Re: Gas gauge?
Thanks the wire looks good but I'll go try to test it and see, this truck is my dd so I need a gas gauge.
Re: Gas gauge?
I over looked a bad spot in the wire it was an easy fix
