05-15-2012, 12:05 PM | #1 |
4wd engine cross member
Can anyone explain to me why the engine is set 2" back on 4wd 67-72 trucks? I'm putting in a torque splitter and one of the options presented would be to move the front cross member forward two inches and the rear one back 5-1/2. I'm thinking this would cause clearance issues with the front axle, but wanted some feedback while I plan this out.
Thanks! mike |
05-15-2012, 02:09 PM | #2 | |
Re: 4wd engine cross member
I'm curious if the water pump/fan shroud are different in 2wd vs 4wd? I'm using aluminum tank with SPAL dual electric fans. No issue with 2 inches less clearance. I'm doing the same mod as you, so I'll be following your progress closely. Let me know how I can help with measurements/photos etc. Last edited by SunSoaked; 05-15-2012 at 02:16 PM. |
05-15-2012, 05:40 PM | #3 | |
As for the water pump and all that, I don't know if there are any differences. I would be surprised if there were any because there is/was a ton of room between the radiator and fan. My guess is that the shroud would be the only difference (and they are listed differently in the LMC catalog). It would be interesting to see the comparison between the 4wd frame and the 2wd frame. |
05-15-2012, 06:06 PM | #4 |
The only answer I can come up with on engine placement on the 4x was for the front drive shaft length and angle on full droop. With the stock suspension and the engine 2''rearward the cv won't bind
05-15-2012, 06:31 PM | #5 | |
I love a challenge. |
05-15-2012, 07:03 PM | #6 |
Beer Drink'n Knuckle Dragger
rotating the front axle is no easy task...you have to cut the knuckles off precisely all the way around on both sides, then using angle finders and levels, you'll have to set your pinion angle then re-weld the knuckles back to the axles...you can shim a few degrees, but i definately wouldn't shim it an extreme amount.
I do know that there are differant mounting position on the frame rails for differant motors. V6 V8sbc and V8BBC so 3 differant engine mount positions, with v6 closest to the firewall and the BBC furtherst from the firewall.
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
05-15-2012, 09:11 PM | #7 |
Currently Blazerless
I've looked my truck over real good and 2" will not be a clearance problem at all..but I'm running a 4" lift also. I've always wanted to do this even before I got my Ranger splitter. It a pain just to replace a distributer cap the way it is..I think the 2" move would make working on the motor much easier.
I know some of the Big Block guys have moved theres forward without problems..maybe one of them will chime in.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
05-15-2012, 09:15 PM | #8 | |
Whoa...you're running a splitter on yours? |
05-16-2012, 12:15 AM | #9 | |
05-16-2012, 10:14 AM | #10 | |
05-16-2012, 02:41 AM | #11 |
6>8 Plugless........
When I put a BBC in my 70 K20, I moved it the SBC cross member ahead 2" and I didn't have clearance issues. IDK why the factory did this because they could have installed BBC's in them from the get go.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-16-2012, 10:37 AM | #12 |
I did this in my truck (2" forward). And have not run it yet but have a splitter (23/205 ORD) and 700r4 and do not see a problem with clearance. I am running electric fans and a four core with serp set-up though. Was a real challenge getting those lower frame rail holes drilled. Used a rt angle drill. Came up with a close tolerance between my headers and the left front spring though. Bought the headers used off different truck so correct ones may not be so close. Sure is easier to get to the rear header bolts and spark-plugs!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-16-2012, 09:57 PM | #13 |
Okay, I've decided that I will move the front cross member up the 2" then the rear 5-1/2 back. Thank you everyone for the valuable input!!!
05-16-2012, 10:19 PM | #14 |
Here ya go Mike, the electric motor is made by Eaton..not sure if this style will work with yours as they changed the shifter mechanism when the company changed hands.
05-16-2012, 10:30 PM | #15 |
Thanks Rob! Yeah, that's totally different than mine. I guess I'm going to have to find something else.
