mini truck racer
Oil leak at slip collar
I have an oil leak at the slip collar on my MSD distributor . I can see it coming from the split were the allen set screw is . The depth is correct and i have replaced the gasket . Anybody ever run into this or have any suggestions ? This is a small block chevy .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
mini truck racer
Re: Oil leak at slip collar
Google is my friend . Looks like a common problem and silicone needs to be added .
![]() Join Date: Jan 2011
Yup with those the solution is just a little black rtv the first time in the hole. Seems to fill the small gap for a good while.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
mini truck racer
Tell me if this sounds correct on the slip collar setting .
Set collar @ .043 gap from intake minus half the gasket which was .062 =.031 depth =.012 . Spec is .010-.030 . .043 gap -.031 ( approx for gasket crush ) .012 depth
Registered Truck Offender
What I do,, is set the distributor in and seat the collar against the intake with no gasket. Then with the gasket added you have around 0.010-0.020. Has worked for me in everything I've used them in.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
mini truck racer
Thanks , again sorry instructions . I found that formula under Chevelle forums . Just wanting to be sure . Tearing up the cam gear would suck .
AS always Marv is on top of it.. And a little dab will do ya on the RTV..
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
mini truck racer
That solved it .
The slip collars are nice but I have had those leak at the collar and shaft.. RTV needed there as well LOL.
